S3 faceflift "headlight range control defective"
Josh williams Apr 12, 2013
  1. Josh williams
    Josh williams Active Member
    197
    40
    Hi there, this has been coming up since i got the car (private) and i now want to get it fixed.
    I've searched and found a few threads saying they just need to be reset through vag-com. Now my question is, has anyone got a definite answer for this?
    Cheers :)
  2. monopole
    monopole Well-Known Member
    1,154
    466
  3. Josh williams
    197
    40
    I'm afraid I don't have nothing like that :(
  4. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Where are you located? Maybe someone local on here can use there's for some beer tokens?
  5. Josh williams
    197
    40
    Im in peterborough! Would be greatful if there was!
    Im also at Early Edition this weekend if anyone is going that could bring one!
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    youll need the adaptation done on the headlight leveller unit, or a replacement, that is if your level sensors or headlights are all kosher
  7. Josh williams
    197
    40
    Could you explain a bit more mate? Is there anything I can do?
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    has this car had the headlights retrofitted?
  9. Josh williams
    197
    40
    NOpe is a 58 plate facelift!
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    hmm probably jsut a sensor then time to invest in vcds!
  11. Ash187
    7,444
    704
    the range control module is usually 'defective' if 1 of the 2 sensors on the axles become faulty or if there is something wrong with the auto levelling control module.
    the sensors are located on the left side (passenger) front and rear axels
    when the car is first turned on do you notice the headlights go up and down before settling or does it not do anything?
    the issue could be fixed with a reset using VCDS or it may indeed need a replacement sensor but the best way to determine what is needed is to get the car scanned with VCDS to show what the exact error is.
    if you wanted to have a look yourself you could always have a look behind the wheels and see if the sensors have their plugs connected and that they are attaached properly? the other thing you could do is take the sensors off and see if they move freely, to make sure they are not jammed in place
    Artimus likes this.
  12. Josh williams
    197
    40
    The headlights do not go up and down when the ignition is turned on!
  13. Artimus
    Artimus Shortback
    2,005
    476
    had this a few weeks ago with mine, both headlight range & adaptation were giving DIS errors, along with no left\right or up\down movement! Audi replaced a sensor under warranty. Turn the lights on before you switch the ignition on to see if they dip\rise.
  14. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Mine had this error soon after buying car. VCDS identified is as the front NS sensor which attaches to the wishbone.
    Dead easy to change. Sensor was about £70 from Audi.
    Also while having tyres changed, they found a slight buckle in the Front NS wheel. Which ties in with the duff sensor..
    If you are in Lincoln sometime, drop by to use my VCDS.
  15. Josh williams
    197
    40
    Thanks for the offer!
    looks like I may have to buy a vcds though :(
