S3 exhaust valve spring re-call
crunchie Sep 14, 2011
  1. crunchie
    crunchie Active Member
    880
    77
    The dealer has told me there is no re-call for the above on my car.
    I figured that being an early 58 plate (October) it would need done.
    Warranty obviously runs out in October and don't want to find issues if I re-map in the future.
    Can anyone clarify this?
    Also, any other things I should ask about?
    Many thanks.
  2. NHN
    29,568
    1,779
    TBH it was for 07 cars & extended to Mk5's, Seats, 8P's etc, if yours isnt in a vin list then it wont be covered, now there's always the chance yours is an anomoly, but only way to know is to check whats fitted atm as they're colour coded, but check if your car has the coilpack recall, a shed load have.
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,487
    633
    Is this the spring located in the left exhaust pipe?
    If so, remove the vacuum hose and cable tie it open - sounds a lot better!
  4. crunchie
    880
    77
    No its for the exhaust springs in the engine, some of them are fitted with the wrong ones and you get valve bounce if you map it.
    I did think about doing the exhaust "mod" before.
    Can you just leave the hose open ended of does it affect other part?
  5. Boydie
    3,487
    633
    The flap will remain closed as far as I remember if you take the pipe off so you have to tie it open.
  6. Shane.
    Shane. Member
    486
    Is this a sort of butterfly valve to decrease the noise when running around town but more growl when booting it?
  7. crunchie
    880
    77
    Tied it open this afternoon, didn't like it, put it back to std.
    I prefer the wee pop that it gives when the flapper is working.
