S3 exhaust valve destroyed
g dawg Jun 26, 2013
  1. g dawg
    g dawg Member
    102
    My valve thing is hanging on by the vacum pipe what do I do cut the pipe or try to secure the unit?!!
  2. shariain
    shariain Well-Known Member
    1,182
    190
    If you cut the pipe you will need to seal it either by inserting a screw in the hole and using something to clamp down on it or by bending the hose a few times and clamping it together so it is sealed. I think you will get an error and you will get a warning light on the dash if its not sealed. Have a search for the flapper mod there was a link to r32oc and it explained it all there.
  3. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    I thought you just left the pipe as is as the linkage is disconnected and locked fully open. The system is still operated by vacuum pressure but wont do anything as the linkage isnt connected. Hmmm......
  4. g dawg
    g dawg Member
    102
    So what happens to the pipe when you fit an aftermarket exhaust?
  5. essIII
    essIII Active Member
    285
    35
    I stuck a screw in it to blank it off when I fitted my Milltek!
  6. g dawg
    g dawg Member
    102
    Sweet blank it off with screw and that annoying clicking sound can do one!!!
    cheers for the advice lads
