S3 Exhaust Manifold - Uprated Options?
funkymofo May 25, 2006
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    lol you know your stuff Ryanc, would you compare it to the gt28rs? or is it much bigger (I know its for a 2.0) but I'm just curious how both turbos compare
  2. Defratos
    2,232
    Got another question guys. Would I need the ATP 3" Inlet pipe upgrade? (I want it) but does it fit on 4wd? and how can the air filter be so low down and so close to the turbo? and I can seem to see all those pipes as on the original inlet pipe.
  3. Defratos
    2,232
    from readin the small print it seems it wouldn't fit, or it does but gives problems with 6speed gear boxs?
  4. Defratos
    2,232
    haven't I already asked this earlier on?
  5. Ryanc
    Ryanc Active Member
    1,321
    Obviously the inlet to the turbo is bigger so you will need a different inlet pipe.Should come with the kit.
  6. ChriS3
    ChriS3 hud at ye bam
    2,239
    24
    The ATP 3" Inlet pipe is for the FWD kits. If you read the info on their site, it tells you all about it.
    Def, have you got your car remapped yet? Might be the best place to start before going for a bigger turbo...
  7. Ryanc
    Ryanc Active Member
    1,321
    evo 8 turbo compressor wheel is about the same size gt28rs or ihi vf34 but it has a bit bigger exhaust housing.
  8. ChriS3
    2,239
    24
    You sure know your turbos Ryan, /ubbthreads/images/graemlins/grin.gif
  9. Ryanc
    Ryanc Active Member
    1,321
    yes alot of thought has gone into my turbo choice.
    Just so you know the ihi vf34 i have on my car is off a subaru sti v7 ra(race altered) but it has the exhaust housing off a vf22( sti 2 ra).
  10. Defratos
    2,232
    so Ryanc, would you say you'd consider gettin an eliminator kit if it was out over the hybrid? (less work?). and Chris no I haven' mapped my car yet, but this turbo upgrade is for the future as I'm looking at keeping the car for several more years (I hope), so I'd rather do one map than two
  11. Ryanc
    Ryanc Active Member
    1,321
    No i don't have a hybrid,i have a full turbo kit ,proper manifold,downpipe etc.Eliminator is a kit for a cheap upgrade.
    I can bolt a bigger mitsubishi/ihi turbo to my existing manifold.
  12. Defratos
    2,232
    ok, so is the key to your full turbo system the proper manifold and pipe work? or also uprated internals? because why would I got for an eliminator kit when you've gone for somethin that seems more up for future modifications?
  13. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    can you get supercharger kits for the 1.8 turbo engine ?
    Matt
  14. Ryanc
    Ryanc Active Member
    1,321
    For me the eliminator is a good cheap upgrade for those that don't want the expensive of exhaust manifolds and downpipe and also runs within the scope of the standard intercoolers and internals .Thats why i'd go for the smaller gt28rs for a steady 320bhp.
    For anything more you'd need manifold,downpipe,perhaps internals.
  15. Defratos
    2,232
    so what turbo do u have Ryanc? =) and how many hoses (horses you running)
  16. god_thats_quick
    2,507
    Ryan, the question that keeps popping into my head is you and a good few others have now gone to the trouble of having totally custom manifolds made (I assume) for your S3s but surely the places that made these custom manifolds could duplicate their work easyily enough which would solve the biggest problem that I can see for a turbo change on an S3 as a custom exhaust and downpipe arn't in the same league of expense I wouldn't have thought. I'm not sure you'd want to answer but how much was your manifold?
  17. Ryanc
    Ryanc Active Member
    1,321
    Defratos- turbo is as i stated above,
    dyno'd at 360bhp.
    My Manifold is cast and is hi-nickel content made in a foundary,it's £500 or £550 with a ceramic coating it is made for ihi/mitsubishi turbos on a 1.8t.
  18. Defratos
    2,232
    Ryanc, 360 is a great figure but what turbo is it? (if u don't mind me askin)
  19. ChriS3
    2,239
    24
    Erm....
    [ QUOTE ]
    [/ QUOTE ]
  20. Defratos
    2,232
    lol... ok cheers for that Chris, you're too sharp dude (or am I just very slow?)
  21. Defratos
    2,232
    money and easy of changing not being an issue, why don't I go for a turbo like yours? seems to fit the hp I'm looking for?
  22. Ryanc
    Ryanc Active Member
    1,321
    You can mate.It will be more expensive ,around 5k+ with exhaust and sports cat.
    You will need a better intercooler to get over 335bhp.
  23. Defratos
    2,232
    ok I understand, cheers for the help Ryanc, will hopefully get it done sometime (sooner rather than latter) /ubbthreads/images/graemlins/beerchug.gif What fmic do u have?
  24. nervus
    nervus Well-Known Member
    1,370
    120
    LOL Defratos,
    You remind me of the kid next door with the constant questions - genuine enthusiasm! /ubbthreads/images/graemlins/grin.gif
    No harm intended! /ubbthreads/images/graemlins/grin.gif
  25. Ryanc
    Ryanc Active Member
    1,321
    Forge Custom made.
    Although there kit for the s3 is well up too the task.
  26. Defratos
    2,232
    lol, I agree Nervus, sometimes I feel bad asking more questions but I think no harm done (seems this lot is willing to put up with me /ubbthreads/images/graemlins/froggie_red.gif) all the better.
    Ryanc I do agree the Forge does seem more solidly built than the star performance one, I could always get a water mist thingy on the front? seems to help the Evo a bit.
  27. Ryanc
    Ryanc Active Member
    1,321
    Well i've had the star performance intercooler and it is restrictive so you will need a better one for more than 320bhp.
    I run water injection 50/50 mix with methanol and these seems to help knock timing back a bit and keeps things fairly cool.
    Not a big fan of the water sprayers.
  28. ChriS3
    2,239
    24
    [ QUOTE ]
    [/ QUOTE ]
    I had my Forge intercooler fitted at Star Performance, don't think they bother with their own anymore.
  29. Ryanc
    Ryanc Active Member
    1,321
    The star performance one had a forge core but running intercoolers in series is never a good idea. I found my custom forge one excellent.
  30. ChriS3
    2,239
    24
    Jim at Star seem to say the same thing. He liked the idea of not cutting into the bumber bar, but thought the Forge kit would be better at it's job.
    My laptop's knackered and I haven't managed to get the VAG-COM cable of Imola_S3 (gimme a call Grant) yet so I've not logged intake temps. Seems to work well...
  31. Ryanc
    Ryanc Active Member
    1,321
    Intake temps are mega low on mine,i've logged plenty of runs.
