S3 Exhaust Manifold - Uprated Options?
funkymofo May 25, 2006
  1. funkymofo
    funkymofo Member
    44
    After reading through several tuning threads about the S3, the general opinion seemed to be that the exhaust system was not restrictive, but the exhaust manifold was.
    So to me this begged the question, is there an alternative "uprated" version available with the standard K04 fitment? If so what sort of gains are to be expected and where can I get one from? /ubbthreads/images/graemlins/grin.gif
    thanks, Rik.
  2. funkymofo
    funkymofo Member
    44
    haha yeah I found that too, but on reading the small print:
    NOT compatible with Quattro cars such at 225TT, 225HP Audi S3 and Cupra
    Still, if these are the sort of prices I could expect then I am pleasantly surprised. Doesnt seem like you can get much thats worthwhile doing for under £500, and if this prevents the manifold cracking then it is probably worth it without even bringing power increases into the equation.
  3. Indeed... you may want to e-mail them though... as I understand it they are in the process of developing a manifold for the Quattro cars etc. They're very helpful... Worth a try .. ?
  4. funkymofo
    funkymofo Member
    44
    waaaaay ahead of you on that one /ubbthreads/images/graemlins/tongue.gif
    mail sent.
    Cheers for the help though, I'll keep you posted on their reply.
  5. Defratos
    Defratos You’re Dethpicable!!
    2,232
    what about "dahlbackracing"?? I've heard they've got reall good manifolds, but not sure if its for the stock turbo etc.. does anyone know if the manifold below fits onto the standard kit?
  6. god_thats_quick
    2,507
    That's the inlet manifold, it's the exhaust one that's the problem! /ubbthreads/images/graemlins/wink.gif
    That said I'm not sure if they also make exhaust manifolds...
  7. funkymofo
    funkymofo Member
    44
    their site says they do.......but at £1100 I think I'll give it a miss /ubbthreads/images/graemlins/frown.gif
  8. elucidate
    elucidate Member
    157
    Yeah, Dahlback are THE guys, they also had a special offer for £800 for the exhaust manifold last month, so i did a print screen to use as leverage when i phone them for mine.
  9. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    I heard the ATP ones should be ready by about August. And they'll be a lot cheaper than the Dahlback manifold - £350-400.
    They better be, the Eliminator kit's depending on it....
  10. funkymofo
    funkymofo Member
    44
    Yeah dahlback do know their stuff, but im not prepared to part with sort of cash for a manifold.
    And Chris, please be quiet before you tempt me into one of those elimantor kits aswell /ubbthreads/images/graemlins/tongue.gif
  11. funkymofo
    funkymofo Member
    44
    Got a reply from them yesterday.
    They basically said that they were developing one but they could not confirm a completion date.
  12. Triple_A
    Triple_A Member
    100
    [ QUOTE ]
    [/ QUOTE ]
    They said me the same thing 4 months ago when i asked those manifolds.
  13. Defratos
    2,232
    Do u need to change your exhaust manifold if you upgrade to the dahlback inlet manifold?
  14. funkymofo
    funkymofo Member
    44
    nope, are you thinking of changing the inlet manifold?
    I dont see the standard being a restriction unless you are going for crazy power (400bhp +). Bet its not cheap either.
  15. Defratos
    2,232
    well, I was thinking along the lines of. Get a FMIC, Sport-cat, Downpipe, and I was thinking of upgrading the inlet manifold to give me 300+, would the dahlback manifold allow me to reach such figures? (assuming the car is chipped)
  16. Ryanc
    Ryanc Active Member
    1,321
    No.Turbo is too small.
  17. Defratos
    2,232
    right, so I can't change the inlet manifold with the standard K04 turbo. Is it cheaper getting a hybrid or a bigger turbo?
  18. Ryanc
    Ryanc Active Member
    1,321
    Dahlback does next to nothing on mine! I would go for one of these new eliminators from atp,not too big a turbo,like a .64 gt28rs.
  19. Defratos
    2,232
    Just been looking at atp, and I can see the gt28rs turbos are much bigger than the K04 turbo. Does this mean I'll have to change much of the internals of the engine? or just inlet manifold and dp etc..? and I couldn't figure out what eliminator kits do? is that the same as gettin a gt28rs?
  20. Ryanc
    Ryanc Active Member
    1,321
    small gt28rs ,injectors should be ok,4 bar fpr ,internals are fine,stock inlet manifold is fine.Go for a decent free-flowing exhaust and possibly dp if you want, de-cat/sports cat ,should see 300bhp+
    Get MRC to map it for you.
  21. Defratos
    2,232
    So there's a small and large gt28rs turbo? I'm guessing the large requires internal to be changed? ok 4 bar fpr won't be a problem(Would MOFO be ok as well), sport-cat and dp are hopefully on the way, so realisticly what would be the small gt28rs's limit? I mean with a few more internals changed e.g. inlet manifold, FMIC and maybe pistons etc... 400bhp with boost control?
  22. Ryanc
    Ryanc Active Member
    1,321
    310-320bhp small gt28rs
    330-340bhp large gt28rs
    injectors would need to be changed for larger turbo.
    Rods would be wise with bigger turbos
    A gt3071r would be good for 400bhp but would need internal work,decent exhaust manifold and a step up in capacity for response.
  23. Defratos
    2,232
    cool, ok so do u know roughly how much is a large gt28rs? and the figure of 330-340hp is that standard (with stronger rods)?could I realisticly get around 370 from a gt28rs? what would I need? really appreciate the help Ryanc
  24. Ryanc
    Ryanc Active Member
    1,321
    About £600 ,i reckon a larger gt28rs if they do a eliminator in this size may see 330ish but i don't know how much of a restriction the standard exhaust manifold may become.Intercoolers also become a restriction at 330ish.Probably will be a bit laggy and you will need injectors.
    Rods are up to you,it's borderline.
    You will never get 370 from a rs ,you'd need to go to a gt2871r but there even more laggy.
  25. Defratos
    2,232
    ok cool, so what about boost control? what figures would i be lookin at?
  26. Ryanc
    Ryanc Active Member
    1,321
    boost control is with the standard n75 using the ecu.MRC will sort this.
    small gt28rs 310-320
    large " " 325-340 (will need injectors)
  27. Defratos
    2,232
    OK, just looked at some older threads to see what the N75 was, I'm guessing maybe with a more aggressive N75 I might be able to boost it up a bit more?. I've got a Star pefromance FMIC lying about, this is the one that goes in conjunction with the existing driver side sdmic, what bhp would you say this is good for? I'm just curious, roughly how much would labour cost be to fit a new turbo?
    p.s. What are eliminator kits? haven't been able to understand that one. /ubbthreads/images/graemlins/beerchug.gif
  28. ChriS3
    2,239
    27
    Eliminator kits are basically Garrett GT turbos with a flange mount that's the same as the OEM mounts. This means you 'eliminate' the need for changing the downpipe, exhaust manifold, changing the pipework in your engine, or creating new mounting points.
    ATP Eliminator info
    I've seen a Seat LCR hit 290bhp with a GT2X kit, so I wouldn't be too surprised if their quotes for the other kits are in the right BHP region.
  29. Ryanc
    Ryanc Active Member
    1,321
    The star performance intercooler becomes restrictive past 320bhp.It will flow no more than 330bhp.
    A n75 is a n75 ,use the one that is meant for the car.
    Yep a eliminator is what you will need to keep costs down.
  30. ChriS3
    2,239
    27
    [ QUOTE ]
    [/ QUOTE ]
    Oh, but it didn't have the standard manifold, downpipe, hoses, intercoolers, etc. so the 'eleminator' idea wasn't in full effect /ubbthreads/images/graemlins/wink.gif
  31. Defratos
    2,232
    ok I kinda get it now. So is there an eliminator kit for the larger gt28rs? or should I just call and check? when you say the FMIC would become restictive would this mean an upgrade to a larger FMIC? Just one more question, would the clucth and any other part of the car be able to handle the power? I know you'll need bigger breaks at the power band, but would I have to change the clutch/ flywheel etc...??
  32. Defratos
    2,232
    another question, just been lookin at ATP's site: which turbo is which?
    GTRS Eliminator Hardware Kit = is this the small or large GT28rs?
    GT2871R Eliminator Hardware Kit = What's this?
  33. ChriS3
    2,239
    27
    ATP do two kits for the S3/TT, the GTRS (350bhp) and the GT2871R (400bhp).
    The clutch won't like much above 300lbs/ft.
  34. Defratos
    2,232
    ok, so which one is the gt28rs? the 350 or 400hp one? or neither? Has anyone here upgraded their turbo? if so roughly how much would labour costs be from MRC tunning?
  35. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    I'd got for the 2871R... But it would be a bit more laggy. Depends what you want.
    Rich
  36. Defratos
    2,232
    when you guys mention laggy, how laggy would it be? my counsin's Evo8 is pretty laggy (kicks in around 3000-3800rpms) but it's fine to drive when turbo is up a spining. Where would you say the 2871R would kick in from? Would I have to fit bigger inlets and exhaust etc..if I go for the 2871R over the GT28RS? or do they require the same goods? hey Rich, how are you running 320 hp? what's IHI-VF34? and ACE112?
  37. Ryanc
    Ryanc Active Member
    1,321
    Gt2871R is very laggy especially on a 1.8 and it won't achieve 400bhp.Full Boost guesstimate ,full boost , 4.5-5k.
    Standard valves sizes are fine but upgraded items are recommended.
    ihi vf34 is the turbo
    ace112 are alloys.
    Yes a single Intercooler with a good core above 330bhp.
    I killed my standard clutch with 345lb/t but it did have 40k on and was a very hard standing start.
  38. Defratos
    2,232
    cheers for that Ryanc, would a hybrid turbo be more work? over the 28Rs? more or less power gains?
  39. Ryanc
    Ryanc Active Member
    1,321
    If you want my honest opinion then ,i'd go for a small gt28x(gt28rs .64) eliminator kit,decent exhaust and downpipe,4 bar fpr.Perhaps intercooler,thats up to you,get mrc to map it.
    Should see a solid 320bhp,320lb/t for mininal cost.
