S3 EXHAUST FITTING... EASY ENOUGH??
SCHOLESY83 Mar 1, 2013
  1. SCHOLESY83
    SCHOLESY83 Member
    42
    Hi,
    I believe to change the 2007 S3 exhaust (2 piece turbo back) it requires removing the driveshaft? Is this true? Is that a straight forward job?
    Cheers in advance
  2. r7ano
    r7ano Race Tech
    31
    The prop shaft needs to be undone at the front to gain space to remove the down pipe.
  3. SCHOLESY83
    SCHOLESY83 Member
    42
    Cheers, straight forward job for any garage mechanic?
  4. r7ano
    r7ano Race Tech
    31
    Oh yes! Only 3 bolts
  5. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Turbo flange bolts meant to be tricky.
    £80-£100 is the going rate for fitting.
    Worth it though as the gains are excellent.
  6. SCHOLESY83
    SCHOLESY83 Member
    42
    Straight forward job... Should have been. I'm now 1 bolt short where the heat shield/cover plate separates the drive shaft and exhaust. Turned out the guy didn't use the little tabs that retain / stop the bolts falling out and now the bolts on a slip road somewhere!
    does anyone know the correct way of using the little tabs that are on this plate? There's 4 tabs, but looks like only one of the 4 tabs is supposed to be bent over the bolts washer. Can anyone confirm?
  7. S3Alex
    10,641
    4,699
    This gives an impression of what a tight space it is....
