S3 exhaust fit a 2.0 TFSI ?
foxymk1 May 30, 2014
  1. foxymk1
    foxymk1 Active Member
    454
    44
    im just wondering if a S3 exhaust will fit 2.0 TFSI quattro, are the turbo manifold where it joins the downpipe the same size?
    thanks in advance
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,760
    354
    Different turbos (K03 vs K04, right?) so I'd imagine different sizes on the turbo, though I think the actual downpipe diameter is the same so maybe not.
  3. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    i have a funny feeling iv read that the k04 is a bolt on to our A3's.
  4. Lewbo
    Lewbo Well-Known Member
    1,266
    105
    Afaik it's bolt on job, as long as it's from a 3 door on to a 3 door ect and an s3 exhaust is good enough for stage 2+ on a k03 as well which is good if that's what you was thinking. Saves buying miltek ect
  5. wuta3
    wuta3 Well-Known Member
    1,129
    347
    Yes it will fit, I have an Milltek S3 TBE on my 2.0T, which assumes an S3 OEM exhaust would fit too.
  6. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    unless you can get a good deal:D. Just saying:)
    wuta3 likes this.
  7. Tezgreig
    Tezgreig Active Member
    123
    34
    I'm pretty sure the exhausts are identical in diameter so wouldn't benefit in fitting a standard s3 exhaust
  8. Lewbo
    1,266
    105
    Why not an s3 can handle stage 1 remap at 310 with standard exhaust, so why can't it be put on a k03 at stage 2 + with 280bhp?
  9. wuta3
    1,129
    347
    Well if you can get one cheap enough, but im sure you could hunt down a milltek for similar cash?
  10. JJ.Foulds
    1,263
    176
    Because k04 is a bigger turbo and has more power for the same restrictive pipe?
    Just a guess, but makes sense. The pipes could be the same but the bigger power turbo will have less trouble with it and make obvious larger gains
  11. foxymk1
    454
    44
