S3 engine change
Scoot123 Aug 30, 2012
  1. Scoot123
    Scoot123 New Member
    25
    Hi there new to this forum. I have a 2001 s3 Amk engine,bought a replacement over the net,when it arrived there is no Amk stamp on block ? Seller assures me it is a Amk,is there any differences with the bam or the apy engines,it looks the same as my Amk ,but don't want to it it then run into problems ?
  2. brasiliangringo
    brasiliangringo Member
    626
    10
    Ask him for the VIN of the car it came from so you can verify through Audi what it was (assuming he gives you the right one) but there should be an engine code somewhere which would be the quicker way to confirm - if not be wary as to where he obtained it from !!
  3. <tuffty/>
    21,800
    4,171
    Look on the block flywheel end... the engine number should be dot imprinted on the edge of the block where the gearbox fits...
  4. Scoot123
    Scoot123 New Member
    25
    If it is not a Amk will it still fit looks same as my amk
  5. brasiliangringo
    626
    10
    Why don't you just check before panicking as it may well be what you ordered :)
  6. Scoot123
    Scoot123 New Member
    25
    I have already had a good look and can't make engine number out ? Ment to be fitting it tommorow !
  7. <tuffty/>
    21,800
    4,171
    use some wet and dry to rub over the top to clean it up...
  8. brasiliangringo
    626
    10
    Get some petrol on a rag and give it a good clean..
  9. Scoot123
    Scoot123 New Member
    25
    If it is another engine as in a bam or apy will it fit ?&nbsp;
  10. Dani_B19
    9,365
    400
    Yes mate, only problem is the apy is narrowband were as your amk and bam's are wideband.
  11. <tuffty/>
    21,800
    4,171
    For reference you will find the engine number in the area I have marked in red (thanks to Stacey for the pic... even if he doesn't know yet ;P)
    You can use a BAM, AMK, APY from an S3... you can use a APX, BAM from a TT, AMK, BAM from an LCR... there are a few other 20mm pinned bottom ends you can use (AGU and whatever the Mk3 Ibiza Cupra is but they use 9.5:1 comp ratio rather than 9:1 of the 210/225's)
    Check the number first... I assume this is a short motor as the engine code is also on the head...
  12. <tuffty/>
    21,800
    4,171
    Doesn't matter when its just the bare engine dude... :)
  13. Scoot123
    Scoot123 New Member
    25
    What does that mean :(
  14. Scoot123
    Scoot123 New Member
    25
    Thanks tuffty, cylinder head with engine so I can get a number off head ?
  15. <tuffty/>
    21,800
    4,171
    It means nothing in context of what you are doing... ignore him.... bad lad Dani!! ;P
    ...but to clarify... the S3's with APY engine codes used an older ECU to the AMK... this makes no difference in your case as all you are doing is swapping the bottom end... (I am assuming this of course as you have not said otherwise)
    Where you could have problems is if its a complete APY you are trying to swap then there are differences on the head... APY has secondary air injection, was non VVT and a different cam cover..
    What exactly is it you are trying to fit? the whole engine or just the bottom end?
    ...and have you sorted that engine number out yet?
    A few pics of the engine would help too
  16. Scoot123
    Scoot123 New Member
    25
    It's full engine I am fitting .head looks same and injectors are the same !
  17. Dani_B19
    9,365
    400
  18. <tuffty/>
    21,800
    4,171
    The head will have the engine code on a tab...
    Find out these codes and/or take pics... can't help you any other way really...
    Does the new head have a VVT tensioner?
  19. Scoot123
    Scoot123 New Member
    25
    ye that's we're it says Amk on old block but new one blank there ? That's we're I am doubting the engine but everything looks same as old engine
  20. <tuffty/>
    21,800
    4,171
    Have you managed to get the engine number off the block yet? its not uncommon for the engine code to be machined off as it could be a fairly generic engine... I wouldn't want to fit it without knowing for sure as there are differnces that could compromise the engine in the case of an S3...
  21. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    No probs did see it and think that looks like my block until I read text and all became clear lol
    Really got to stop treating asn like a 2 year olds picture book and read some info lol ;)
  22. Dani_B19
    9,365
    400
    Lmfao, i do The exact same thing mate so your not alone.
  23. aragorn
    18,579
    868
    Audi refurb heads dont have anything on that tab.
    The engine number should be on the edge of the block as mentioned above.
  24. <tuffty/>
    21,800
    4,171
    Thats why I fill my build thread full of pictures for you guys ;P
  25. Scoot123
    Scoot123 New Member
    25
    Will try clean block and get engine number tommorow,thank guys.
  26. Scoot123
    Scoot123 New Member
    25
    That's the engine in and sounding nice,hopefully have it out on a test drive tommorow,thanks guys.
  27. <tuffty/>
    21,800
    4,171
    Did you find out what engine code it was?
  28. Scoot123
    Scoot123 New Member
    25
    I take it it was a Amk ,spoke to guy who I ot it from and he said it was ? In and running nice,It had a stage 1 remap with original engine in,will new engine be ok with map ?
  29. Miguel_S#
    Miguel_S# Active Member
    337
    29
    The diference on the compressor ratio is made only by the piston?
  30. <tuffty/>
    21,800
    4,171
    Yes
  31. Miguel_S#
    337
    29
    its a good ideia in a apx engine swap 9.0:1 piston to 9.5:1???
