S3 DV hard to get at?
S3Si Oct 24, 2006
  1. S3Si
    S3Si Member
    99
    Need to service my DV and had a quick look under the bonnet but noticed the DV seems to well obstructed by various pipes and the strut brace, or whatever its called. Is it just me being a bit lame and really not that much bother or is it fairly tricky to get at for all?!
  2. Defratos
    Defratos You’re Dethpicable!!
    2,232
    wellll, as far as I remember it was quite easy. take off the engine cover, if you want also the airfilter and that should give you enough room. Taking the DV out is a bit of a struggle (nothing too serious) just pull it out of the two big hoses and unclip the small one on top, should be a dodle, here's some pics, not very helpful I know:
    http://00626e1.netsolhost.com/formoshun/s3/Dump Valve.htm
    Good luck :beerchug:
  3. Adams3
    Adams3 Member
    425
    I have the same DV as you, whats involved in servicing it??
    How often should it be done too?, when the car is serviced or more regularly than that??
  4. Defratos
    2,232
  5. Adams3
    Adams3 Member
    425
    Cheers for that!! Might do this at the weekend weather permitting!!
  6. S3Si
    S3Si Member
    99
    Thanks people, will give it a go, still looks a bit tricky though!
