S3 down on power
Bigandbald Sep 9, 2013
  1. Bigandbald
    Bigandbald Member
    105
    31
    Help, I can't diagnose this but suspect vacuum/boost leak or MAF failure.
    since fitting my S2000 filter the car bogs down under 2k revs, and has a noticeable lack of power in the higher gears. Just seems to take ages to get from 80-100mph (private road of course)
    any ideas? I guess I need vag com to do logs etc but don't have it!
  2. vivalacoulter
    vivalacoulter Active Member VCDS Map User Gold Supporter Audi S5
    408
    60
    Try unplugging the maf sensor. Doing so allows the car to use default values, if it's better with the default, then the sensor is naffed and you'll need a new one. Another new OEM maf is the best replacement.
  3. vivalacoulter
    408
    60
    If there's no difference then you'll need to take the car for a smoke leak test which is the best way to find a boost leak.
