S3 door trims: rust magnet?
DiscoPanda Jun 28, 2007
  1. DiscoPanda
    DiscoPanda Member
    159
    I was reading on the other S3 forum ('96-'03) about how the plastic trim thats on the bottom of the door has caused rusting due to it trapping moisture/dirt. Is this likely to also happen to the new S3? Or has it been better designed?
    http://www.audi-sport.net/vb/showthread.php?t=13861
  2. JohnS3
    JohnS3 Active Member
    3,032
    The doors no longer have the plastic trims attached to them. But they might still catch leaves and **** behind the wheel arch liners ;)
    Regards, John.
  3. DiscoPanda
    DiscoPanda Member
    159
    Really? lol I was examining 55/56 plate A3's in the car park at work which had them. So the S3's doors are metal all the way?
  4. steve184
    steve184 Active Member
    1,138
    an S3 is no differnet to any other A3 body-wise and my march 07 A3 has plastic trims at the bottom - so yes they do have plastic trims at the bottom - i for one think this is an extremely good idea since if you ever catch the door on a high kerb or the like it will not rust - plus easier to get repaired dont have to repaint the door. Can't see how these would cause rust, especially since the body of the car is galvanised also.
    I would worry in the slightest.
  5. DiscoPanda
    DiscoPanda Member
    159
    The 8L was the same setup though - galvanised. 2002 cars are rusting as its a water trap. Sure it saves scraping the paint in the short term but its a bit of a design flaw I feel. Unless they've done somehting differently? :S
    The strip removed from an 8L model S3.
