S3 door moulding... door blades
simch Aug 24, 2009
  1. simch
    simch Active Member
    2,028
    I ordered a new lower door moulding for the drivers door of my S3 as it was clipped in a car park few weeks back, and just a bit scuffed on the top edge...
    First, WTF, £155.....!
    Second, when i opened the box, it is not grey plastic like the originals, it is in light grey primer.
    Bodyshop who are fitting it, said, oh, maybe they are painted, but I am sure they are just grey plastic like the bumper inserts. I have not been back to the supplier, (audi garage) but as far as I a aware NO s3s had painted door mouldings as standard, ie bodycolour.
    Anyone else bought one and had the same problem. Is the grey finish paint, if so, anyone know the paint code?
  2. jojo
    29,001
    3,658
    Should be around £70 from Audi and it's primer coated from the factory, I fitted mine straight on, and it isn't too far off the original colour so left it.
  3. jojo
    29,001
    3,658
    Rear part original, door part new.
  4. simch
    simch Active Member
    2,028
    Mine is a 53 plate and the originals are loads darker grey than the primer that the moulding was in. Checked invoice and it was over £115+ VAT, I got 15% off!
  5. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    I got one the same, primer coated & nowhere near the original colour...
    Tried asking them if they had a pain code for them & noone can help...
    Anyone out there know? Or I might have the whole lot colour coded to match the car...
  6. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i brought the whole lot both fronts and both rears that hurt my pocket!!!
    they all come primered i guess there is a paint code for them but the bodyshop should be able to use a colour chart to get the colour or near as damn it,
    i had all mine and the front bumper insert and rear bumper insert pannels painted in a gloss grey effect similar colour to std but with the laqured finish looks so much better
  7. I've just had my originals painted, I picked a colour off the bodyshop colour scheme. It was from the 'plastics' section and the colour I picked matched perfectly (not that it mattered because I was spraying them all). It was covered with matt laquer so it didn't look like shiney paint.
    The bodyshop should be able to let you pick a colour that matches, and then they can make up the right amount from their scheme (like 50ml or so) and it shouldn't cost too much.
    Or, even better, respray all of the side strips, or even better the front and rear too. The side stips come off very easily, the rear side strips just slides off whilst the door is open!
    The front and rear insert should come off without removing the bumpers, but I did this with bumpers off so can't be sure.
  8. jojo
    29,001
    3,658
    How odd, I'm sure mine is the correct colour, it doesn't feel like primer, and I'm pretty sure mine was under 70 quid, maybe the facelift is different slightly, on the fitting front?
  9. simch
    simch Active Member
    2,028
    Audi reckon it is paint code 1RR Platinum Grey.
  10. S3quatt
    652
    60
    Finally got mine painted & fitted early December.
    A month on & already the front is starting to chip. Kinda tells me that they are originally grey plastic & not primed. I figure there might be 2 different types available although I've never seen another S3 with painted mouldings...
    Anyone else?
  11. sportstractor
    sportstractor Chugger
    2,709
    dont suppose anybody could confirm this as im on the hunt for the paint code?
  12. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Not really a helpful comment for the above question, but these are defo dark plastic and not painted on mine as well!
  13. Dani_B19
    9,500
    438
    I need to to order a drivers side one still :sob:
  14. sportstractor
    2,709
    well iv taken the plunge and ordered 1/4 litre of platinium grey, hopefully that man is right
  15. sportstractor
    2,709
    this is not the case, the colour is still a mystery.
    although now one of mine is now platinium grey, should have probably tested it first:ermm:
  16. mephisto
    mephisto Member
    271
    "Bump"
    Did anyone get to the bottom of the paint colour for the door trims, looks like i have to order one from a stealer for OSF Door ouch here we go..
  17. S3quatt
    652
    60
    Funny this should come up again, the passenger side one has started to come apart & will need replacing soon!
  18. A4Paul
    A4Paul Member
    33
    Well,i need a drivers and passenger door moulding,and they are now £204 plus vat!!!!!!!!!!!Is there anywhere else apart from audi to get them from?
  19. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,234
    11,364
    ​Paul, have you looked in the classifieds section for cars breaking for parts ? :) x
  20. A4Paul
    A4Paul Member
    33
    Yeah,cheers.Have only found one,but they are painted black
  21. jojo
    29,001
    3,658
    Paul, just repair them yourself mate, my new trick repairing my passenger one was to remove the end screw and find a longer screw with smaller thread, stick a washer on it and screw right through the bolt hole into the plastic, pulling it against the door. Add a blob of superglue onto the end of the screw to make sure it's going nowhere!
    CMcKenzie likes this.
  22. jojo
    29,001
    3,658
  23. CMcKenzie
    CMcKenzie It's supposed to do that..
    318
    127
    43
    Looks like this is how I'll be fixing my drivers door soon.
    Cheers jojo!
    -Callum.
  24. jojo
    29,001
    3,658
  25. S3_DAVE
    S3_DAVE Active Member
    105
    41
  26. CMcKenzie
    318
    127
    43
    I'll have to see how I get on with mine, not sure what the screws are like, either way it needs doing before it gets any worse.
    Cheers again.
    -Callum.
  27. A4Paul
    A4Paul Member
    33
    Thanks for the replies,may wrap them then,as they aren't loose.Its going in for paint next month,and has a rust bubble of the bottom of the doors,which has stained the door mouldings
  28. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    Just the 1? You was lucky fella....all of mine were completely dead and siezed :(
    Just the drivers side door ended up taking well over 2 hours after I had to drill the old ones out and find suitable replacement screws and washers.
    Typical 10-15 minute job took 2-3 hours with the unplanned modifying! lol
  29. s3mad_dude
    s3mad_dude Noggies ruuuule!
    623
    81
    This sounds familiar!!! Mine were the same and took me the best part of two hours to fix too!! I got a painter to spray all of mine in a dark matt grey colour. They look great.
  30. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have got myself a spare set and plasti dipped them. Just waiting for the chance to fit them now.
    Sent from my iPhone using Tapatalk 2
  31. Pacetree
    Pacetree New Member
    24
    I've just spent the good part of the last 2 hours getting both door blades off mine and I had to destroy all of the screws, bolts and white nylon inserts to remove the blades. Pain in the ****... Also getting the remnants of screws out of the door for the 2 middle screws was like a game of Operation!
    Now that I've gone and completely destroyed the white nylon bits (not to mention the bolts that were part of these bits as well) I'm guessing that my only option is to get some new ones. Doh!
