S3 Doesnt get up to full temperature
Omniquito Sep 10, 2012
  1. Omniquito
    Omniquito Member
    55
    Hi all,
    My newly aquired 2000 plate S3 either takes forever to reach 90 or usually never gets there and hovers around 60 to 70 and often gently fluctuates between the two.
    MPG is also rubbish at an average of 22 to 24 mpg and I drive like a granny most of the time! could it be because it thinks its cold and over fuelling?
    Could this be in need of a new thermostat do you think?
    Cheers, Neil
  2. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3 Manual
    193
    15
    Coolant Temp Sensor and Thermostat :)
    Replaced both of these on mine and MPG went to normal and the Temp never deviates from 90 (once it's warmed up of course).
  3. Omniquito
    Omniquito Member
    55
    sounds good to me :) thank you
    Just out of interest, where is the temp sensor and roughly how much did you pay for the two?
  4. BuckleyTDI
    BuckleyTDI Member
    94
    majority of the time fella it will just be you thermostat stuck which is an easy fix, i would recomend replacing it with a genuine part tho as the pattern parts dont have the best review. genuine ones aint that dear anyways
    james
  5. Omniquito
    Omniquito Member
    55
    thanks buddy, I will seek out the genuine part then
  6. sportquattro
    sportquattro Active Member
    845
    51
    CTS is right hand side of the engine bay (as you look at it) just forward of the corner of cylinder head.
  7. Greg-S3
    Greg-S3 Active Member
    576
    67
    Does your car have any history? Do you know when the water pump was last changed (chances are it was done with the cambelt)
