S3 do change before remap on 8p? And other advise welcome on 8p tuning
l6rth Aug 8, 2012
  1. l6rth
    l6rth Member
    85
    Hi all, haven't been here in a while and I'm thinking of stage 1 mapping my s3, seen people saying you should change the dv first is this the case or is this only needed on older models? I was going to change the filter to a pipe cross panel also and then get an r tech re map.
    Any feed back would be most helpful.
    Rob:idea:
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    If you have older Rev.C DV I'd be inclined to change it when the old one fails for latest OEM model.
    Wouldnt bother with panel filter, the OEM air box is the weak link, not so much the filter. Either CAI or leave as is.
    Worth an oil change to give best starting point and ensure car is protected in new running parameters.
  3. l6rth
    l6rth Member
    85
    It's a 58 plate, how would I know if it's a rev d? Heard of people smoothing the box is that worth it? Don't want to get an induction kit.
    thank for the advise
    rob:respekt:
  4. warren_S5
    7,210
    2,487
    On side of unit it should give revision letter, but on a 58 plate it won't have a rubber orange diaphragm. Will be later model.
    Airbox smoothing on 1.8T did help, but not seen any reports on 2.0T cars. The airboxes are thin (I've just sawed one up) so buy a spare to do it on.
  5. l6rth
    l6rth Member
    85
    So is the orange diaphragm the best option for the standard dv? Won't bother with air box etc and just get it mapped
    Thanks for all you help, you have saved me a few quid.
    Rob
  6. warren_S5
    7,210
    2,487
    The early revision C DV's had a rubber orange diaphragm which over time could split with heat/age.
    The revision D DV has a fully solid one piece mechanism, and I ran this variant for 30k with stage 2+ on last car with no issues.
    The one your car is the best one so you'll be fine with that, so more money saved. Possibly worth spending the saved £40 on the DV for new plugs to get the very best from the map if they've been in the car from new!
  7. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
  8. l6rth
    l6rth Member
    85
    Going to the ttshop in Bedford tomorrow to get revo'd, he advised me that if I didnt change panel filter it would restrict the map. Soiled be a fun drive home.
  9. warren_S5
    7,210
    2,487
    Im currently running with stg 1 and OEM filter and I wouldn't say it restricts it. Sometimes businesses might just want to sell you something extra in this economic climate, so be strong and decide what you want mate. You can always mail order it later.
  10. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    Although changing intake for something decent will make a difference. Panel filter unfortunately is just a gimmick thing and wont help due to **** OEM air filter design.
  11. essIII
    essIII Active Member
    285
    35
    He speaks the truth!
    In my opinion, if you're sticking with the OEM box, save a few quid and stick with the OEM filter.
  12. S3Alex
    10,801
    4,805
    Spot on as ever,Warren.
    The stock intake will work up to Stg2 but admittedly not beyond.
    Panel filters are a bit of a waste of money and when or if Stg2+ is reached,then you need a good intake to avoid air flow limitation.
  13. l6rth
    l6rth Member
    85
    Hi all, had the map done and am now running 310bhp, the difference is awesome. Money well spen I think.
    thanks r ll the advise.
    Rob
  14. l6rth
    l6rth Member
    85
    I have started a group for bag owners in the east angina area as I could not find one to join, if you know anyone from this area please let the know.
    Rob
  15. S3Alex
    10,801
    4,805
    East Angina region will give you chest pain!
    Essex and London have plenty of members here.
  16. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,027
    553
    glad you like the remap :D
    don't buy the panel filter as it's useless. enojoy it as it it's and when you want more power buy a decent intake, exhaust and hpfp :D
    it makes a big difference :D
  17. l6rth
    l6rth Member
    85
    Stupid IPad, I mean east Anglia. Hpfp I take is high performance fuel pump?
    :nyah:
  18. S.
    2,027
    553
    pressure instead of performance but yes :D
  19. l6rth
    l6rth Member
    85
    Had the car mapped a few weeks ago and was thinking about an oil change, what bet to put in a tuned s3? And what is t next thing you all would do after a remap
  20. big harty
    big harty Member
    307
    15
    Don't bother with panel filter. Go for forge twin. There great. I would recommend revo tuning. Mine was great after remap. Save up for hpfp then mIlltek full system. Then stage 2 +. Then you will be flying:salute:
  21. l6rth
    l6rth Member
    85
    Already revo'd and love it, my only concern re induction kit is the sensor in the air box, how do you deal With that?
  22. Rob W8
    Rob W8 Member
    953
    It unscrews and bolts into the intake pipe on the new one.
  23. nluk100
    nluk100 Well-Known Member
    1,031
    192
    Always a good idea to change plugs when remapping - use OEM or RS2 plugs (1 stage cooler).
  24. S3Alex
    10,801
    4,805
    Most seem to be advising using the OEM plugs,but changing every 5 000 miles or so,and certainly if any full throttle misfires occur.
    This is the advice I've followed and the car reliably runs around 500bhp at 2bar.
  25. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    The next stage for you is removing the pre cat and going to a larger down pipe, and an uprated High pressure fuel pump.
    Thanks, Rick
  26. RedDejavu
    1,806
    337
    then save money to pay your insurer big bucks for all the mods LOL!
