S3 D.I.S just died
vanilla_ice Oct 5, 2006
  1. vanilla_ice
    vanilla_ice Active Member
    707
    HELP!
    Just filled up with petrol this morning and like to reset the trip and MPG on the computer. The last time I filled up the D.I.S screen went completely blank for a few seconds and then came back and worked as normal. Today however, it went blank and has no stayed blank.
    If i press the left stalk it still displays the miles until next service and completes the check with an "OK", but the screen then turns off again.
    Is there anything I can do to revive the display? I have heard getting D.I.S issues repaired can be costly :crying:
    Any advice greatfully received.
    Cheers,
    ICE
  2. s3shabs
    s3shabs Member
    155
    there should be a button underneath the right stalk which switches the dis on and off..
    try that. I dont think its faulty if it initially powers up. happened to me a few times until i realised there was a switch for it.
    hope this resolves your problem.
    shabs
  3. vanilla_ice
    707
    Thats the button I use to reset the MPG. Maybe the switch is faulty - I'll go try.
    Thanks,
    ICE
  4. vanilla_ice
    707
    Panic over!
    Thanks s3shabs!!!! I didn't realise if you pressed it quickly it turned the DIS on and off and if you held it, it resets the MPG etc.
    Thanks again,
    ICE :blush:
  5. Tallpaul
    Tallpaul Member
    835
  6. s3shabs
    s3shabs Member
    155
    Your welcome mate..
  7. Adams3
    Adams3 Member
    425
    I only found out about that from JoJo at inters!!
    Maybe i should :rtfm: !!!!!!!! lol
