S3 cylinder head
DamoS3 Sep 12, 2006
  1. DamoS3
    DamoS3 New Member
    12
    I`ve got and 01 210bhp S3 engine code AMK. The cylinder head is cracked so I need a replacement. The problem is I have located two S3 heads with engine numbers BAM and APY. Is the head any different on these as my car is an AMK? I have rang audi but the parts guy did`nt know!
  2. Ryanc
    Ryanc Active Member
    1,321
    amk has vvt so you will need the bam.
  3. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    i thought Bam had vvt to
  4. DamoS3
    DamoS3 New Member
    12
    so the head with the BAM code would be the same as my AMK. Just making sure before i buy it. cheers.
  5. Ryanc
    Ryanc Active Member
    1,321
    Yep,both vvt.
  6. tommo-turbo
    tommo-turbo Member
    164
    Which of the heads is the one that has the larger valves?
  7. Ryanc
    Ryanc Active Member
    1,321
    All have the same size valves,you mean larger ports.
    I believe the only a3 is the early agu 1.8t's.
  8. DamoS3
    DamoS3 New Member
    12
    got talking to audi again today and the said the part no. for the two heads (amk&bam) are the same, happy days.
  9. Ryanc
    Ryanc Active Member
    1,321
    Think i told you that a while ago!
