S3 cuts out when warm :-s !! Anyone else had this ?
motfree Jan 29, 2011
  1. motfree
    motfree Member
    464
    Hi there ..
    Driving along the other day and my S3 suddenly cut out and would re start .. After getting the aa out they thought maybe crank sensor due to it being head related ..
    Anyways got it too an audi specialist and they cant find any fault codes that it didn't have 6 months ago ( lambda sensor )
    Just wondering anyone else had this problem ?
  2. Ian W
    Ian W Active Member
    1,058
    12
    I went through a stage of this happening, strange as it sounds it was my knee knocking the key and switching it off lol
    Tim_Attard likes this.
  3. motfree
    motfree Member
    464
    Haha wish this was my problem :-(
  4. finesse
    finesse Active Member
    2,805
    scan the car vagcom
  5. motfree
    motfree Member
    464
    Already done no fault codes
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    youve just put the engine in right? check all connectors again and the main fuses
  7. motfree
    motfree Member
    464
    Well it's at a specialist I think they've have a good look over it and they can't seem to work it out .. Got to be something like that though i guess as no faults are coming up .. Was fine for a day or 2 after getting engine fitted though that's what I don't understand !!
    Never had Soooo much hassle from a car before haha
    If it was something not connected properly wouldn't that show on the diagnostics ?
  8. motfree
    motfree Member
    464
    What could be the results of my s3 doing this ?? Eg coolant temp sensor ... Etc
    Its just I've been told that faults don't always show up on diagnostics so might do bits to rule this out and see where I stand as the garage don't seem too keen on sorting the problem out !!
  9. Ian W
    Ian W Active Member
    1,058
    12
    Where is it?
  10. motfree
    motfree Member
    464
    Discount audi vw in elsmereport ..
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    That made me LOL how tall are you?
  12. Optimum Tuning
    Optimum Tuning www.optimumtuning.co.uk
    37
    ive had a similar problem with a tt a pipe in the tank had come off.first job- try to monitor rpm signal when cranking with vag com
  13. motfree
    motfree Member
    464
    Was this when the car was warm though ?? It was fine before I had the new engine put in and everything off my old engine has gone on this one ..
  14. Optimum Tuning
    37
    The tt cut out and would never start again and no fault codes stored .best to go back to basics with yours i think mate,has it got a spark ?does it have fuel pressure etc? then go from there. The ecu must think everything is within parameters and circuits must have continuity for it to show no fault codes.e.g no fuel pressure will not show any faults as there is no sensor!
  15. Broken Byzan
    13,237
    465
    Crank sensor is a common one, and it doesnt always throw a code as many have learnt already.
    When it failed and the AA said it was the crank sensor, did you replace it?
  16. Ian W
    Ian W Active Member
    1,058
    12
    Only 5'10
    My key was pretty ruined though and used to just hang down, it was only when I was in full relax mode on the motorway i'd do it lol
  17. motfree
    motfree Member
    464
    When it was recovered by the aa he made sure fuel was coming through then he checked injectors .. Also checked there was a spark .. God hate cars sometimes haha good when they ain't poorly !!
    If there's fuel getting through and a spark I'm not even sure where to go from there ..
  18. motfree
    motfree Member
    464
    Not yet because wanted to get it plugged in first .. I've been told could be a number of things but a crank sensor is £30 .. Coolant temp sensor £30 ish need to borrow parts I think haha
    But only cuts out when it's warm .. Then leave it for 20 mins half an hour and starts straight away ..
  19. Broken Byzan
    13,237
    465
    the temp sender usually affects the way it starts and runs and not make it cut out.
    We have seen a good few on here with warm failure of crank sensor. Once cut out, i assume it won't start until it's been stood?
  20. motfree
    motfree Member
    464
    Yep have to wait for about 20 mins then will start up straight away but cut out again once reaches certain temp ..
    Doesn't it always show on diagnostics then ?
  21. motfree
    motfree Member
    464
    Engine speed sensor .. Would this cause the engine to cut out like described ??
  22. Broken Byzan
    13,237
    465
    yes, same thing, just a different name mate.
    be wary of buying pattern parts too on these especially
  23. 1animal1
    9,978
    my monies on the crank sensor....... make sure the pattern part is the right one, a well known VAG parts bloke sent me a golf item which ISN'T the same regardless of fitting in the same hole.....mine cost £35
  24. motfree
    motfree Member
    464
    Well the garage said they think this is the fault .. But £60 odd plus vat !! Bit steep I think !!
  25. finesse
    2,805
    Yellow : Oil filter
    Red : Crank/speed sensor
  26. 1animal1
    9,978
    £60!! try and fit it yourself on the drive :) ....trust me, if that includes the part, its a bargain.......half hour labour for a garage with a ramp
  27. motfree
    motfree Member
    464
    Well just said to them fix it as I didnt know where to start haha .. Well rang them this afternoon and they said £140 plus vat for diagnostics , oil and filter change and the sensor so isn't too bad I guess .. Be glad to have it sorted !!
  28. 1animal1
    9,978
    just hope that does it mate..... welcome to never having any money lol
  29. motfree
    motfree Member
    464
    Haha I'm supprised I've still got it to be honest I get bored very easy but I think the speed keeps me keen :)
  30. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Already suggested this to OP when he PM'd me - lol.
  31. Audi_Alex
    Audi_Alex Member
    59
    Hi Guys,
    it looks like I have got the same problem with my S3. When it tries to cut out on me, i shift it into a lower gear and the engine starts again for another few hundred metres. Does this point to the crank sensor going?
    There are no fault codes either
    Thanks in advance for any help
  32. chazza55
    chazza55 got an S3 8L: living the dream
    173
    When my crank sensor went I usually was able to almost get to work (4miles) before it was warm enough to cause problems.
    When cold, the resistance was within spec, when warm (after cut out) it was out of spec.
    Sometimes got fault codes, sometimes didn't. When I did it was for the cam shaft intake side being over advanced/retarded.
    In the early days of the problem I was able to get to work but the engine would have gone into limp home with an epc light in the dash
  33. Audi_Alex
    Audi_Alex Member
    59
    Hi chazza,
    This sounds exactly like my problem at the moment, so did you replace the crank sensor and all was fine afterwards?
    I've got a quote for a new sensor to be £118.37, seems quite steep doesn't it?
  34. chazza55
    173
    yup - all was fine after the new sensor was fitted.
    fitted myself......quite easy......1 single allen key screw near the oil filter.......need to get the front on ramps/axle stands to get under the car to do it.
    think i paid about £106 for mine - cant remember where from (maybe audi as eurocarparts didnt have the bosch version, only some pattern part).
    so i guess your quote isn't too far off..............unless you can find one from a breakers yard? but then you dont know how much life is left in that one.
    I am actually still using a sensor from a spare VW Bora engine my friend had.......that has been running for over a year now with no issues....but will do intend to fit the new sensor this "summer".
    Good luck with it!
