amb276s3
bird spotter
a quick mod for anyone running single FMIC on S3, I installed this on my S3 just to help get cold air to the factory box, remove n/s front wheel and arch liner, using a 60mm dia hose,( i used one from a pipercross kit), thread one end along the cavity in the inner wing and then angle down towards fog light where n/s i/c used to be, it is a very tight fit, the other end can then be moulded onto the exposed triangular shaped factory air feed, replace arch liner which holds air tubing tight and replace wheel.
Car now roars like a spitfire, 0-60 in less than 4 secs, and i had it off the clock when testing. AB /ubbthreads/images/graemlins/wink.gif
