S3 coilpack recall, misfire and other problems
Mi7rennie Nov 7, 2012
  1. Mi7rennie
    Mi7rennie Member
    82
    Hi Guys,
    Just had my 2002 BAM S3 in at Dundee audi having it checked for the coilpack recall. According to them they are all of the correct type so don't need changed.
    I'm pretty bummed about this as the car has developed a misfire, very slight at idle, fine when driving gently but as soon as you try accelerate hard as the boost rises the car starts misfiring and power is reduced.
    When it does this I tend to back off the throttle, but if I keep my foot in then I get a CEL warning light.
    I've done the N249 bypass and I'm going to fit a catch can this weekend.
    I guess it could still be a faulty coilpack that is causing the misfire.... any other suggestions?
    Audi also informed me that there is a broken spring on the rear, it's lowered on Eibach springs, does anyone know i you can by these individually?
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    Did they scan it for fault codes?
    Does the car idle lumpy?
    As it could be anything from split pcv pipes down to a shot 02sensor and everything inbetween.
    Catch can and n249 delet are good mods anyway, but id clean the throttle body both sides and check for perished pipes to the inlet manifold.
    Hope this helps.
  3. <tuffty/>
    21,885
    4,204
    Airs leaks are a common issue so check for those (smoke test helps)... misfiring under load could be a lean AFR issue... this could suggest a tired fuel pump... pressure gauge test on the fuel lines would be an idea as would logging of fuelling blocks under load in VCDS...
    A scan for fault codes would be first port of call...
    This may also be relevant... seen this on BAM engine codes so far...
    Fuel system too rich fault code? see inside, it might be this - SEAT Cupra.net - SEAT Forum
  4. Mi7rennie
    Mi7rennie Member
    82
    the thing was it was running fine when I bought it. only done 700 miles but it does seem to be getting worse!
  5. <tuffty/>
    21,885
    4,204
    Sadly means nowt mate...
    Scan it first and post the faults...
    Check for splits etc in any pipe that looks plastic or rubber (mostly under the inlet manifold)... if there is oil there is most likely a split pipe...
    Log the car in VCDS to test fuelling (block 031)
  6. Mi7rennie
    Mi7rennie Member
    82
    There is a very slight miss at idle.
    I'll need to contact one of the VCDS guys neer me and see if they can help with logging.
    I'm also going to check pipe work tonight and clean the injectors as per the FAQ.
  7. Mi7rennie
    Mi7rennie Member
    82
    So injectors ultrasonically cleaned and fpr cleaned.
    Still missing.
    Going to do the catch can and TIP at the weekend.
    hopefully get the car on VCDS too. I'll post logs here.
  8. Mi7rennie
    Mi7rennie Member
    82
    Changed the fuel filter, the fuel inside was very dirty and black. Still missing.
    Going to do the catch can mod and TIP and change to 2.0 TFSI coil packs this weekend.
    Also noticed that the earth strap from the coil loom to the top of the rocker cover doesn't look too good. Maybe I'll chop it out and replace it with a new piece of cable.
  9. Mi7rennie
    Mi7rennie Member
    82
    coilpacks fixed it! happily boosting again
