S3 Coilpack lifting up help!?
campbell Jul 26, 2010
  1. campbell
    campbell Member
    721
    when i checked my coilpacks on my audi S3, cylinder 1 is half way stuck up and needs pushing back down, any ideas? As i dont think that is normal. All coilpacks are genuine audi, as i know there is performance lost
    Any help most appreciated
  2. <tuffty/>
    20,779
    3,656
    Coil packs have a rubber seal to help them stay in however as they tend to trap air when pushed in the heated air expands and pushes the coil pack up as they are sealed... a fix (courtesy of Badger Bill) is to cut a small section of the ribs in the rubber of the coil pack to allow air to escape...
  3. campbell
    campbell Member
    721
    nice one Tufty, you are a legend! Always happy to help
    Thanks very much
  4. fingermouse
    fingermouse thats me
    3,974
    110
    Check your spark plugs I had one that was loose and caused the same issue. Then I had one that the top of the spark plug unscrewed and welded into the coilpac causing same issue. Worth a check
  5. lukens3
    lukens3 Member
    42
    ive got the same problem but 3 of mine jump out nearly every time i drive it . thanks tuffty
  6. barters3
    barters3 Member
    438
    awesome gti sell an ECS coilpack holdown kit. Obviously more expensive than tuffty's tip (in the regoin of £40)
  7. campbell
    campbell Member
    721
    I have tried Tuftys tip by cutting the rubber and it works! Thanks
