S3 clutch
Samks3 Mar 19, 2013
  1. Samks3
    Samks3 New Member
    Hi I have a 2010 3 door s3 it's done 19k miles, after driving the engine bay smells a hit like hot cluth! :( the clutch isn't slipping at all but I have this smell! Is this bad and should it be looked into?
    Thanks, Sam
  2. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    I would do a little invest into where the smells is coming from......a burning clutch has definately got a distinct smell which cannot really be mistaken for anything else so I would be looking.
  3. Samks3
    Samks3 New Member
    I have looked and that's all I can suspect. The only thing confusing me is that it doesn't slip! Can it smell without slipping?
  4. Brodster
    3,548
    882
    It doesnt have to slip to smell. If your clutch has been dragging i.e holding it on the clutch with say pulling a trailer or whatever the clutch would smell but not slip. Lots of use as in city driving would do the same.
    Your clutch could also be on the way out (internal failure of bearings or clutch plates not releasing properly)
    Im not a clutch expert but have witnessed and smelt one without it slipping.
    Hope this is of use to you. A clutch expert will probably be along soon to give you a better insight.
  5. Samks3
    Samks3 New Member
    Ok thanks! :) just a thought but can a diff smell if it has a fault?
  6. smurfworth
    smurfworth Well-Known Member Audi S3
    1,918
    532
    Any mechanical part that isn't working correctly will have a certain smell
