s3 clutch issues
S3Matt1983 Jan 4, 2007
  1. S3Matt1983
    S3Matt1983 New Member
    17
    Set off from traffic lights yesterday and on pressing the clutch to change from 1st to 2nd i felt something give and a small piece of metal broke off and now the clutch wont come back up from the floor. Any ideas peeps?
  2. tommo-turbo
    tommo-turbo Member
    164
    I'd be inclined to say get your master cylinder checked mate. Mine had similar symptoms, although I didn't have any metal breakage and it wasn't that sudden. I struggled to get it in to gear for a day or 2 and then the clutch pedal started to struggle to come back up from the floor.
    HTH
    Rich
  3. IzzyK
    IzzyK New Member
    This has happened to my car a while back...it turned out to be a broken clutch pedal assembly (some plastic clips holding the clutch pedel in place) rather than a clutch.
  4. S3Matt1983
    17
    clutch pedal assembly sounds about right to me, thanks for the quick responses, ive pm'd you izzy
  5. claudefrog
    claudefrog Member
    372
    you will need a new clutch pedal, its a common VAG problem
  6. S3Matt1983
    17
    Any idea how much this is going to cost me, is it something i can do myself, or would i best to take it into a vag specialist?
  7. Mo-S3
    Mo-S3 Member
    708
    It can be done if your fairly competant mechanic. Its not a hard job but it is fiddly and if you think about where it is then you might think twice. Very cheap if you can do it yourself but expect to pay some good money from a dealer as their labour rates arent cheap
  8. darko
    darko Member
    272
    do a search through my old posts - there are pictures of the problem, its easy to fix and down to terrible design by vag... when you get the new pedal you can weld it so the problem will not happen again
  9. S3Matt1983
    17
    Found your old post Darko, thats a great help, if u have the part number for the clutch pedal pls can you post it, also where did u purchase your parts from, and is the 'special tool' worth purchasing??
    Thanks again
  10. darko
    darko Member
    272
    ill have to look through my bills and see if i have the receipt - if you pop into your local audi / vw / seat / skoda dealer they should be able to get it for you.
    refitting is totally possible without the special tool you just have to be patient and make sure no one who might be offended by swearing is in ear shot.
    when you get the new pedal you will see there is one edge not welded, take the pedal to someone who can weld that for you, once you have gone through replacing this part you dont want it to EVER happen again ! after mine was welded i sprayed it with black paint to stop rust but thats probably not essential
  11. darko
    darko Member
    272
    these are the parts i replaced:
    1 X Mounting - 1H0721357 £0.55 + Vat
    1 X Stop - 1J2721332A £1.47 + Vat
    1 X Clutch Pedal - 1J2721319C £16.82 + Vat
  12. S3Matt1983
    17
    Cheers Darko, thats a great help. I have ordered the parts today, i will take your advice, and weld the weak link that has caused all the problems to avoid any future issues, hopefully i will have my car on the road by the end of the week.:beerchug:
  13. S3Matt1983
    17
    Cars sorted now turned out to be quite a painless fix, as i was able to get it to mates garage and do it there. Cheers for everyones help
