S3 Chain Timing issues...anyone got any experience
Harveysmith Jan 30, 2014
  1. Harveysmith
    Harveysmith Member
    93
    Hi all
    As mentioned above Audi believe that i have an issue with my chain timing. the issue is that the car wont rev above 5500rpm, literally just dies, the ECU cuts all power, the engine is smooth all they up to that point. we have changed the DV, camshaft and crankshaft sensors and MAF and now i am at this point. no fault codes are being shown and Audi believe its not being picked it. They want £516 to investigate further after paying them £216 for the initial investigation!!!!!
    does anyone have any experience in this matter and would it cause the mentioned symptoms?
  2. S3Alex
    10,807
    4,808
    I have to say at this point I'd take the car to a good independent tuner.
    Don't shoot any more in their direction,and go to the nearest place recommended by people here.
    Roughly where are you?
  3. Harveysmith
    Harveysmith Member
    93
    I live in Plymouth, Devon PL99UH.
    thanks Alex
  4. Lee540
    Lee540 Member
    123
    10
    RK Engineering in St Agnes, Cornwall
    Or
    AVS in Pool nr. Redruth, Cornwall
  5. Harveysmith
    Harveysmith Member
    93
    Blimey that's 70 miles away from me!
  6. S3Alex
    10,807
    4,808
    might want to edit those postcodes a bit....good lcuk
  7. Lee540
    Lee540 Member
    123
    10
    Sorry, I didn't use postcode but you said Plymouth. I live in St Ives and Plymouth is 75 miles. The place in St Agnes I'd recommend, they look after my Audi and are specialists in VAG and general turbo cars also.
    Don't know any where north of the border though..
  8. S3Alex
    10,807
    4,808
    I'm sure someone will be along with some more suggestions shortly,but I do think you need someone who knows what they're doing.
    I'd recommend my guys but that would be a serious trek!
  9. dandav1985
    dandav1985 Active Member Team Panther TFSI Owners Group VCDS Map User Bronze Supporter Audi S3 s tronic
    432
    94
    Have you been to transit garage near tesco crown hill. There one of the better ones on Plymouth.
    Cheers Dan
  10. XFi
    XFi In need of a V8.
    491
    47
    I'm sure someone had the same issue on here and it was a cam sensor or something... hopefully he will see this thread as I can't remember who it was now...
  11. Harveysmith
    Harveysmith Member
    93
    Already camped the cam sensor and the crankshaft sensor
  12. Harveysmith
    Harveysmith Member
    93
    Here is a video of what's happening. It's actually got worse
    S3 8p won't go over 500rpm - YouTube
    Just spoke to garage and they said they haven't changed the crankshaft sensor only checked it and it's reading
  13. s3joe
    s3joe Active Member
    562
    79
    That's a mad fault that have you had your cambelt done recently
  14. Harveysmith
    Harveysmith Member
    93
    Well it was dint about 4k ago
  15. s3joe
    s3joe Active Member
    562
    79
    Have the sensors been replaced with genuine ones
  16. Harveysmith
    Harveysmith Member
    93
    Yeah all parts are from TPS. I have instructed them to replace the crankshaft sensor Monday.
  17. s3joe
    s3joe Active Member
    562
    79
    Can you not do it yourself
  18. Harveysmith
    Harveysmith Member
    93
    Good news!!!! It's fixed!!!! Turns out it was a faulty crankshaft sensor. Thanks for all your help appreciated it
    S3Alex, warren_S5 and ACWKGYTO like this.
  19. ACWKGYTO
    ACWKGYTO Well-Known Member
    1,254
    381
    Nice one !
  20. s3joe
    s3joe Active Member
    562
    79
    very nice
  21. Jonse
    Jonse Active Member
    448
    49
    Wish I read this earlier I had the same fault at the beginning on jam and swapped the cam shaft sensor. Good news it's all good.
