s3 CDA CARBON AIR FILTER GROUP BUY
womb raider May 19, 2010
  1. womb raider
    womb raider Member
    52
    anyone intrested in these filters?
    part no CDASP-02
    these are on ebay for about £210
    i have emailed one of the selllers who will supply 10+ at a discounted rate.
    he said hes on holiday buy will email me when he gets back
    ill update price when i know, but how many of u want one? ..
    cheeers
    jay.
  2. <tuffty/>
    21,691
    4,121
    No offence mate but these things are rubbish... panel filter in OEM airbox flows more... If you want a cold air feed type setup the Carbonio CAI is a better option tbh..
  3. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Highly restrictive air filter systems these.
    Paul, any links to the Carbonio? Was told yesterday that we can't get one for the S3 as the side mounted intercoolers are in the way?
  4. <tuffty/>
    21,691
    4,121
    I don't but you have a good point... all the Carbonio installs I have seen so far have been fitted to Ibizas and Leons tbh... You may be able to fit one if you have a FMIC but the pipe work does make things tight and the relocated horns could be a prob... I fitted my horns back in the OEM position with some mods so room can be found but still has to be said the BMC CDA isn't that good flow wise...
  5. JD09
    3,096
    46
    What are you currently running filter wise Paul? I know you have a standard airbox, so presume Green Cotton or other?
  6. 1animal1
    9,978
    instead of the CDA im goin to selotape £200 to my existing air box as i think the notes will absorb some of the heat from the engine and therefore make my airbox more efficient......
    or should i buy a CDA and reduce it's power....i hate decisions!!
  7. <tuffty/>
    21,691
    4,121
    Green Cotton :)
    I also have a piece of 4" ducting going into the airbox fed from just behind the headlight replacing the rather pitiful OEM airbox intake :)
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    I'm going to do the same to the Jetex I'm running, good shout Tim.
    Sorry to the OP - we're not digging at you, it's just that those air filters really aren't great, especially not for the money they cost..
    I got a Jetex from Badger5 for MUCH less than that, and I have found it to be really good.
  9. womb raider
    womb raider Member
    52
    thanks for the advice atually,
    ill be sticking with standard airbox for now then,
    just wanted something new and shiney
    when u say the jettex is good this just a cone or they do one with an inline cone and cold feed attached, so would imagine this is better....
    cheers
    jjay
  10. badger5
    9,560
    2,028
    Jetex one wellys got is a plain cone.
    add some duct for a cold air feed and you will nett some more airflow
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    i saw 15 gs more, when i took my cda off, although it wanted cleaning they are ok for a standard s3, as i got 195gs out of mine
    ive got mine for sale on here... definatley not recommended for a stage 2
