S3 Callipers
ScottD3 Apr 8, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    I got a set of S3 brakes to convert my brakes from 288mm to 312mm.
    Will the S3 callipers fit?
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    i asked the same question and the answer is yes but aragorn said they use a smaller piston than the a4 ones
    so as long as you have ate calipers in good working order already there's no point it would just be more work bleeding brakes
    i am curious as to what difference a couple of mm in piston size makes, never heard of s3 owners swapping to a4 calipers
  3. Bradderz_1988
    3,995
    262
    I dont think they do scott as they have straight screw in fitting on the calliper where as ours iirc have a small brake pipe and a union fitting wear the pad wear indicator connector is if you got some custom brakelines then id say they probably may fit but i just used the existing caliper as tgere almost identical.
  4. aragorn
    18,663
    878
    Yeh, the stock calipers have 57mm pistons, whereas the S3/TT ones have 54mm, so you'd actually reduce your braking effort.
    As bradders says the brake pipe fittings etc are a bit different.
    Just keep the stock A4 caliper and use the S3 carrier.
    You can then stick the A4 carrier on with the S3 calipers and put them back on ebay as standard 288mm A3/golf brakes ;)
  5. ScottD3
    15,166
    1,126
    I'm not worried about bleeding. I'm replacing the fluid.
    The size difference on the pistons will effect peddle travel but can't see how it will effect the braking effects.
    I'll check these callipers and mine and I'll stick with the best set or even rebuild a set, I got enough time.
    Which pads do you I order?
    I don't want to order normal 288mm pads cause they won't use the full disc surface, do I order S3 pads?
  6. Bradderz_1988
    3,995
    262
    The 288mm pads use the same disc surface as the 312mm ones, heres a pic of a caliper and you can see what i mean by the fitting on our caliper.
  7. aragorn
    18,663
    878
    Simple physics.
    Force = pressure x area.
    Pressure is related to the force your leg would apply to the pedal.
    Area is the size of the piston on the caliper.
    given area = pi x r^2, going from 54mm to 57mm is about 10% reduction in braking force for a given pedal pressure.
    going from 288 to 312mm disks only gains you about 8%.
    You dont really want to be using the S3 calipers.
  8. ScottD3
    15,166
    1,126
    I'm only questioning it cause when I looked at these S3 brakes the pads covered the whole surface of the disc.
    When ever I've seen any one do a 288-312mm conversion there pads never use all the surface of the disc.
    I'll try and find some pics.
  9. ScottD3
    15,166
    1,126
    Got it.
    I wont.
  10. aragorn
    18,663
    878
    Scott: the pad surface area is the same, it just sits further out from the centre with a bigger ventilation gap.
  11. Broken Byzan
    13,244
    468
    You probably have 280's on there scott dont you?
  12. ScottD3
    15,166
    1,126
    From Jason.S build thread.
    Unless I'm missing something, I don't think thats a 288mm pad.
  13. ScottD3
    15,166
    1,126
    288mm, I checked it a couple of times.
  14. aragorn
    18,663
    878
    110 TDi's got 288's.
    It is a 288 pad.
    On the 288 disks theres not as large a gap between the central hub, and the pad surface:
  15. ScottD3
    15,166
    1,126
    Ahh ok.
    That makes sense.
    Ta.
