S3 - Buy Now or Wait?
andywaddy Jul 17, 2011
  1. quattro81
    quattro81 All the gear.. No idea
    970
    90
    So to go back on topic.. I think paddy and I have established that as long as you have the correct tax disc holder, the choice of s3 is a little academic...?
  2. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,326
    188
    If i had know they came in twist off i would have kept the 3.2 !! As it was the tax ran out so i sold it quick :)
  3. Hellz
    Hellz Geordie Racer
    387
  4. andywaddy
    andywaddy Member
    133
    Haha...so basically if I don't have an Audi tax disc which is like fort knox to undo, I won't get accepted into the club?
    ...better take a quick trip to ebay then...
  5. Hellz
    Hellz Geordie Racer
    387
    ...Make sure you buy a new and improved twist off... gotta move with the times :ohmy:
  6. akash_sky1
    akash_sky1 Active Member
    1,181
    The engine block is actually made of vermicular graphite cast iron, the first time it has been used in a petrol engine. This material is has much higher tensile strength then regular cast iron and so enabled Audi to make the cylinder wall much thinner, and hence a lighter block, the engine only weighs 183KG.
    The 2.5 TFSI is a very different engine to the 2.5 NA 5cylinder in the USA jetta- not even based on the same block!
  7. paddy
    5,326
    188
    Yes but it weights more than my old V6 3.2 and that was supposedly ripe for understeer in the A3 chassis and that is why they have tried hard to lighten the front of the RS3 and TTRS.. Its a trade off which is never a great marketing angle for a brand new model and thats why i dont think they will have the nerve to put it in a new s3, or A3 come to that. You cant just take an engine, you have to add the Turbo and intercooler and rads etc. From what i can see the TTRS weights 50kg more than a TTS despite lightning up the front and its still got a weight distribution of 60/40...even my old 3.2 was better than that.
  8. akash_sky1
    1,181
    The extra weight doesn't come only from the bigger engine though. Remember the RS is putting out a lot more power so the entire drivetrain must be stronger, so the extra weight also comes from bigger brakes, heavier gearbox / drivetrain internals etc.
    Also the understeering nature of the A3 3.2 and haldex A3s in general ( which is much less then most FWD hatchbacks) is not just due to nose heaviness ( from the big VR6) but also from the way Audi have set the chassis up. The RS4 was also very nose heavy but did not suffer from that heavy power understeer at all thanks to a good chassis set up.
    And With a transverse front engine and 4wd ANY car is going to be front heavy.
