S3 brakes under 17s
Mike071288 Apr 2, 2010
  1. Mike071288
    Mike071288 Active Member
    287
    26
    Right ive done a search but cant find anything on this.
    Ive just bought some s3 brakes for car but im not sure they will fit under my 17s.
    Can anyone shed some light on this, i dont want to spend all that time fitting them to find they dont fit under the wheels.
  2. N8
    17,163
    718
    You got an 8P now Mike?
  3. Mike071288
    287
    26
    Yer mate, it was the only way forward after crashing the 8l
  4. N8
    17,163
    718
    Change your avatar and get some pics up, you got much planned?
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,434
    570
    No point with 17s mate - you will slide and skid about the place and the TC will be on all the time!
    Plus, it will look silly, the arches are massive in the 8P's and will look lost!
    The carriers/calipers are pretty big and are even a tight fit behind my 19s
  6. chrissy1502002
    chrissy1502002 Member
    238
    Unfortunatley you will need at least 18's for them to fit.
  7. Mike071288
    287
    26
    Got air on its way, currently looking for wheels
    @Boydie
    I dont intend on keeping the 17s for long, i am looking for 19 s-line wheels at the moment, but i was just wondering if i could fit the brakes before i got the 19s.
  8. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Not true. Same brakes as a 3.2, and the Sport 3.2's only had 17's.
    Why would the car slide and skid with 17's? Same 225 section tyres. A higher sidewall will nto cause the car to skid about the place.
    I'm sure they are less of a tight fit behind your 19's than you think.
  9. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    ^^^^ I agree with what V6Pete just said ^^^^
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    Yup, I agree too. Larger wheels are more about looks than handling due to a larger unsprung mass. You will have less sidewall flex which will make it turn in quicker but it may make it twitchy if you go too low a profile IMHO
  11. V6Pete
    1,491
    PETE TALKS SENSE :rock:
  12. Khufu
    5,704
    31
    I'm looking out the window to see if the sky is falling down!!! LOL
  13. N8
    17,163
    718
    Pete is full of win.
  14. NY_Sportback
    NY_Sportback Member
    58
    Should fit no problem, I had them on mine with 17's for winter
  15. N8
    17,163
    718
    What air?
  16. Dan!
    Dan! Quattro Drive
    278
    I just stuck a pair on my BE with no problems. It has 18's but still had room so I don't know why they would be a tight fit behind 19's?!
  17. Mike071288
    287
    26
    Accuair switchspeed
  18. Mike071288
    287
    26
    Cheers for that mate, i just got to find the time to fit them now :)
  19. Dan!
    Dan! Quattro Drive
    278
    If it makes you feel any better, I managed in just under an hour. It wasn't that bad since they are a direct fit. Only thing that confused me was when I bled the brakes not a single air bubble came out! Do these have an 'auto bleed' system somehow or something?!
  20. Mike071288
    287
    26
    Would be good if they had a auto bleed system becuase i dont have a bleed kit yet lol
  21. PH1L
    PH1L Gievf Buckets
    3,851
    40
    if they do fit must be really tight, i hope they do for my snow rubber
  22. N8
    17,163
    718
    Where you gettin that from?
  23. Mike071288
    287
    26
    Voodoo motorsport, were doing the offer over on E38.
    Thay made it hard for me to say no, at the price they were offering it for.
  24. Dan!
    Dan! Quattro Drive
    278
    Just use a bit of hose, its the easiest way! :icon_thumright:
  25. N8
    17,163
    718
    Sounds good Mike, keep us updated with pics etc..
  26. Mike071288
    287
    26
  27. N8
    17,163
    718
    Will have a look now lad.
