S3 booked in for remap
Cra16v Aug 5, 2013
  1. Cra16v
    Cra16v New Member
    22
    hi all my 2007 is booked in for stage 2 custom remap at performance torque next month and i carnt wait, anybody else used these? and what figures are u getting? how much of a step is it going from standad to stage 2? thanks craig
  2. S3Alex
    10,803
    4,805
    I haven't any experience of them to be honest,but assuming their Stg2 is the same as most other tuners version,then it does make a big difference.
    The biggest difference is to use software specific for an uprated HPFP such as the Autotech or Loba,as this smooths out the torque dip in the midrange that you would otherwise get,and if it's being done next month,you may want to think about it.
    Have you uprated the suspension as well?
  3. buz
    buz Flat out
    192
    69
    Will at P Torque remapped my previous Cooper S Clubman and did a good job, he's well known in the MINI scene as tunes the challenge race cars.
    I wouldn't hesitate in using him again except he's only got a 2WD dyno so I'm looking at going to R Tech in the near future with my S3.
  4. Banjo789
    Banjo789 New Member
    Remember to budget around £1200 for a new clutch in the next few months. My 40k S3 clutch lasted 6 months after being remapped. My 225 TT lasted 50k on a remap by comparison.
  5. hades-
    9,481
    646
    1200 who robbed you ?
    Brodster likes this.
  6. S3Alex
    10,803
    4,805
    Depends on what sort of clutch you want.
    If you go for an OEM replacement,you can get them cheaply,and even the Sachs can be had for a decent price,but the Loba and other similar clutches are not cheap.
  7. Dean_T
    Dean_T Active Member
    645
    139
    43
    I used to hear good things about Will and P Torque on seatcupra.net, he has done a fair few maps for mk2 leons on there :)
  8. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
    £950 for a stage 2 Loba Sachs clutch from me including SMF.
    The LOBA-Sachs sports clutch kit includes:-
    • Sachs Performance clutch cover
    • Sachs Performance clutch disc organic
    • LOBA Billet lightened & balanced single-mass flywheel made of special chromoly steel (6.7 kg)
    • clutch cover screws
    • Torque rating 550 nm / 405 lbft
  9. T3KT0N1K
    T3KT0N1K Member
    104
    9
    I'm having this kit installed at AmD tuning tomorrow for £1300 (plus release bearing, if required, for an extra £55+), after having had Revo put stage one remap, induction and recirc dump valve on my car, then subsequently boiling the clutch not two hours later on the quarter mile. Heed these guys warnings. Budget for an uprated clutch and flywheel.
    S3Alex likes this.
  10. Jtaylor
    Jtaylor Active Member
    165
    56
    What sort of power can the DSG handle?
  11. S3Alex
    10,803
    4,805
    Power is not the issue,it's torque,as with any clutch system.
    The DSG can manage around 400lbs or so with a remap,and after that,you need a new clutch pack.
    HPA Motorsports and SSP can supply these but as with all things like this,they are not cheap.
  12. Cra16v
    Cra16v New Member
    22
    Cheers for replys guys already have the loba stage 2 clutch fitted as the clutch was sticking to the floor on hard driving. Don't want to put fuel pump on yet as I want the loba one which are expensive so that will be next year with hopefully a loba lo400 :) haven't done anything with suspension as I think the rides stiff/hard enough and I've lowered cars and I think it ruins them personally.
  13. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    ARB + ALK are essential even at stage 1
    S3Alex likes this.
  14. S3Alex
    10,803
    4,805
    What RedDejavu said.
    The car will feel OK on standard levels of power,but it gets properly wobbly when you start raising it's performance.
    Changing the ARBs and adding an antilift kit won't harm the ride quality,but it will vastly improve the grip and body roll.
  15. turbonutz
    turbonutz Active Member
    421
    61
    just interested in what kind of ALK you would recommend for a bit of playful fun but not serious tracking as in value for money not professional kit alex?
  16. RedDejavu
    1,806
    337
    You can buy Whiteline ALK or Superpro ALK, both similar however Superpro seems to be a bit more reliable however fitting takes longer as its just bushes you replace with the OEM ones. Whiteline does a whole metal mount + bushes so is less fiddling but apparently prone to cracking.
    whiteline:
    Superpro ALK:
  17. S3Alex
    10,803
    4,805
    To be honest,you really don't have a huge number of choices.....
    There's the Whiteline kit,at around £160
    Whiteline Anti Lift Kit Golf Mk5/Mk6
    and the Supaloy kit,which I have.
    Supaloy
    If I remember,it's about £350-400,but includes a lighter,stronger TCA.
  18. RedDejavu
    1,806
    337
    Is there that much difference between S3s & Supaloy TCA?
  19. S3Alex
    10,803
    4,805
    If you look at it,the Supaloy TCA is much better finished and more robust,plus of course has all the bushes uprated,and the ALK chucked in so to speak.
  20. Revo Steve-W
    Revo Steve-W Well-Known Member
    634
    429
    If you want it Revo'd, there's a 20% sale on until 18th August!!
  21. turbonutz
    421
    61
    so just change bushes can increase handling then? i get tht obv the ARBs will be doing best part tho.
  22. RedDejavu
    1,806
    337
    I have my car booked in to do just the ALK bushes however could have done the whole front arms if they are worth the hassle:p.
  23. S3Alex
    10,803
    4,805
    Changing all of the bushes isn't a cheap job but will improve overall feel.
    The ARBs will make a BIG difference.
  24. S3Alex
    10,803
    4,805
    I think that when you've done everything else like upgraded the suspension and bushes etc it does make a difference.
    Mine had all of that and more done and this was like the icing on the cake almost.
    The difference from the TCA alone is not a big one.
  25. H17YD L
    H17YD L Active Member
    383
    76
    R-Tech only have a 2 wheel dyno, simple disconnect of the Haldex underneath an your sorted, Nik does all this in about 2 mins
  26. buz
    buz Flat out
    192
    69
    According to their website its a 4WD dyno
  27. H17YD L
    383
    76
    Strange, it's definitely not lol. Unless its been installed since yesterday
  28. RedDejavu
    1,806
    337
    ARB are just fantastic, did mine and the car drives just much much better however still understeers so fitting superpro alk next week + lower engine mount and maybe new coils next year.
  29. buz
    buz Flat out
    192
    69
    Best I double check then as that and their good feedback was what I found appealing!Thanks for heads up.
  30. Ginger Prince
    Ginger Prince Member
    189
    Hi all!
    Ive just stumbled across this thread which is good & bad....
    Good - explains why the S3 feels wobbly as f*ck on slight corners at speed!
    Bad - more money!
    Ive not done anything to the suspension, never wanted to as I always thought it was cosmetic (until now) which effected performance / ride.
    Can I please confirm, which need doing (ARB, ALK, suspension) what order & why?
    Thanks as I appreciate it,
    Mike
  31. RedDejavu
    1,806
    337
    ARB cause standard suspension is poo and very wobbly not to mention oversteers like mad! ARB give you less roll and car feels much more stable round corners (front soft rear hard set up works best imo). ALK because you get extra grip and more feel through the steering wheel, set of coils would make the whole car tigher and sharper but its not a must can stick to stock set up if money is short.
  32. Ginger Prince
    189
    Thanks pal, looks like my next plan will have to go on hold....
    I'll take your advice & have to look where sells / fits ARB & ALK in Manchester and cost it all up.
    Mike
  33. S3Alex
    10,803
    4,805
    From stock,the S3 is basically setup to be brisk but not fast,and also to be safe(i.e. understeer) as well as fairly comfortable(i.e quite soft suspension).
    So,what you get is a car that works OK on the stock suspension,but when you push it,feels a bit vague and soft,and will understeer heavily.
    My recipe for sorting it was as follows...
    1.ARBs ,as this makes a big difference.
    2.Suspension,which also makes a big difference to the way the car rides and handles,and vastly improves performance on bumpy roads,where the stock gear gets wobbly and confused.
    3.ALK and TCA mods can be done next,but don't add as much as the first two.
    4.Suspension bushes are worth considering along the way as they do tighten everything up,and sharpen handling,but do them if you're doing the suspension to save time and cost.
    5.Haldex controller will take a bit more understeer away and improve traction.
    I wouldn't recommend this unless you're at Stg2+ or above,as the difference is pretty subtle.
    The ARBs are pretty cheap,and there are suspension kits from a few hundred pounds to several thousands so you have a wide choice.
    Have a look through here for a few pics of the suspension and ARBs if thats any help to you.
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/106134-time-build-thread-big-turbo-10.html
  34. Ginger Prince
    189
    Cheers Alex!
    I'll have a look but what (I realise I'm going to sound like a donkey) does TCA stand for...?
  35. S3Alex
    10,803
    4,805
  36. Ginger Prince
    189
    Educated with thanks ;)
    S3Alex likes this.
  37. S3Alex
    10,803
    4,805
    My pleasure.....this place educated me as well!
  38. Ginger Prince
    189
    This place is leading me to debt! :)
    RedDejavu likes this.
  39. S3Alex
    10,803
    4,805
    Tell me about it.... :banghead:
  40. Ginger Prince
    189
    Sent you a PM Alex, no rush re response.
    Cheers, Mike
