S3 Black Edition rotors - repair?
batch Jul 7, 2012
  1. batch
    batch Well-Known Member Team Glacier Audi S3 quattro
    2,486
    3,250
    Hello lovely people! Hoping someone can help me on this...
    Just kerbed the NSR wheel of my car trying to get out of the way of an ambulance on a blue light run - no one to blame but myself though! It's only minor kerb rash, however given the unique colour and very fine diamond cut of the blade tips, am I going to struggle to get an OEM finish to any repair? Anybody had experience of refurbishing a rotor off any Audi?
  2. Old-Boy-Racer
    Old-Boy-Racer Guest
    I repaired my Avus alloys on an S4. I got hold of silver spray and clear lacquer from Wurth. Make sure you let the silver dry (at least overnight) and give it a light key with Scotchbrite before lacquering otherwise it goes gray where ther is loose silver 'dust' on the surface or where it is not fully dry.
    Wurth supply the 'standard' silver paint and lacquer to VAg/BMW/Merc. Not sure about non standard silvers.
    Hope this helps.
  3. mjr901
    mjr901 Guest
    These will be slightly different to deal with as they are diamond cut.
  4. batch
    2,486
    3,250
    Thanks guys. Read elsewhere that a replacement wheel is only £145 so may do that if a mobile repair company can't get it right?
  5. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,083
    10,768
    Where from ?, I thought these were £1720 a set of 4 from Audi.
    Cheers.
  6. Blacksheep
    Blacksheep New Member
    Alloy Wheel Refurbishment by Alloy Wheel Repair Specialists
    These guys, based in Tewkesbury, Gloucestershire, can do this.
    I have a 2011 S3 Black Edition which had a kerb mark on the NSR wheel on purchase, sorted perfectly at Reinventing the Wheel.
    You know you're onto a good thing when you turn up to see an Aston Martin V8 Vantage in the workshop having both rears refurbished!
    If you are within striking distance of Gloucestershire I recommend them. If not, it can be done, and I hope you get it sorted.
  7. batch
    2,486
    3,250
    I've got a horrible feeling I'm going to be buying a new wheel...
  8. batch
    2,486
    3,250
    Thanks for the help Blacksheep, unfortunately I'm nowhere near Tewkesbury however if they can sort my wheel I might have to make the trip! It is just on the very edge of the rim so hopefully can simply be machined out... Also I've heard N8 may be able to assist?
    the only issue is that Audi diamond cutting is so fine, unlike most, and the matte finish.
  9. N8
    17,163
    720
    Yes can refurb this wheel, I need to refurb my own rotors ;)
  10. mjr901
    mjr901 Guest
    umm N8? you've not nailed your 20's??
  11. batch
    2,486
    3,250
    Thanks N8, could you possibly PM me your number as I wanted to run it and some other stuff past you!
  12. batch
    2,486
    3,250
    See it really isn't that bad just hope it can be saved! Guessing a spot repair just machining the rim may work!
  13. N8
    17,163
    720
