S3 Bhp at the wheels???
keendean Feb 27, 2006
  1. keendean
    keendean Member
    358
    I'm buying a second hand S3, it ran 172bhp atw a few years ago, is this right, or does this sound low? It's a 210bhp model.
    Also would a 99 S3 which had warranty work for injection system and cylinder head replaced in 2001 bother you at all?
    I called Audi customer services who cerfied its Full Audi history and all warranty work, v.helpful.
  2. god_thats_quick
    2,507
    Sounds about right, the quattro system makes transmittion losses quite high, I'd be surprised if you could find an S3 that's not had some sort of warranty work so it wouldn't bother me, I'd rather it'd been sorted than not.
  3. madvw
    madvw Active Member
    2,489
    actually sounds a little high to me... I thought the loss was more like 50hp.
  4. JimmyTheSaint
    JimmyTheSaint New Member
    26
    I had my standard 210 S3 on the new rollers at Awesome GTi a couple of months ago and it made 172.6 bhp @ wheels and 191.6 ft-lbs @ wheels.
  5. madvw
    madvw Active Member
    2,489
    [ QUOTE ]
    [/ QUOTE ]
    perhaps not then......
  6. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Power figures are for bullsh!ting your mates in the pub.
    You should go by how it drives not what it says on paper!
  7. keendean
    keendean Member
    358
    What about
    Slightly worried about the above.
    Doh-Just read the thread, I guess so, just major work for an car that was still so young.
    As for the power, I think he disabled the quattro system, so not a very good run.
    I drove it, bit flat at 80mph in 4th, but seemed ok though to 100mph, defo needs a remap.
    I guess they are heavy cars with a hefty quattro system.
  8. madvw
    madvw Active Member
    2,489
    "I drove it, bit flat at 80mph in 4th" - hmm, it should really pull to the redline.
    If your getting the impression on acceleration that "they are heavy cars with a hefty quattro system" then there's probably something off there.
    they're not fast cars, but they are rapid. The closest car i can compare mine too is a MK2 golf (acceleration, not handling). The low torque is nice, like a digifant, and the top-end likes to rev, like a k-jet.
  9. god_thats_quick
    2,507
    At 80mph in 4th my S3 would be pulling rather quickly towards the redline no hesitation at all.
    What car are you comparing the performance too - that may help us understand.
  10. nervus
    nervus Well-Known Member
    1,370
    120
    [ QUOTE ]
    [/ QUOTE ]
    Are you saying your S3 only pulls like your MK2 golf? Was your golf a Rallye?
    I dont think the S3 can be described as being "low Torque" either. The Torque figures a relatively high for the engine capacity and hp.
  11. Ess_Three
    Ess_Three Active Member
    5,383
    12
    [ QUOTE ]
    [/ QUOTE ]
    GTQ...I tried to PM you toady...but your inbox is full...want to clear it out a bit?
    Sorry for the hijack...
  12. Ess_Three
    5,383
    12
    [ QUOTE ]
    [/ QUOTE ]
    A very valid point... /ubbthreads/images/graemlins/wink.gif
  13. madvw
    madvw Active Member
    2,489
    oops, fat fingers there...
    I meant low end torque, like a digifant.
    and high end pull like a valver.
    No, I never did own a rallye, I decided that would be a very bad idea due to the lack of parts.
    I'd still compare the 1st and 2nd gear acceleration to that of my 8V GTi, but 3rd gear and after it was just disappointing.
  14. god_thats_quick
    2,507
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    ah bugger it, I've deleted a load now - don't think the part of the inbox that tells you it's at 100% capacity works!
  15. AL_B
    AL_B Active Member
    1,589
    15
    [ QUOTE ]
    [/ QUOTE ]
    I would be a little worried about that. Its my understanding that pulling the fuse to the Haldex (quattro) unit is not a good thing to do. They are expensive to replace.
    Also, by him doing that you haven't really got a proper power figure anyway. Even if is at the wheels.
    Warranty. I don't think the injector work would bother me. But having the cylinder head off might. I guess you should check around the gasket for oil etc. Maybe try to find out why the cylinder head was taken off.
    Like others have said in some recent threads on here - the mechanicals of these engines are pretty solid, unless they have been stressed by big-turbo kits AND ragging them when cold. Its itty bitty sensors and a **** plastic DV that tend to go wrong mostly.
    AL
  16. keendean
    keendean Member
    358
    I presume the Quattro works, would it bring up a fault? It was just serviced with Audi and they found no problems with the car.
  17. AL_B
    AL_B Active Member
    1,589
    15
    Yeah, it would probably bring up a fault. And if Audi have recently serviced it, then things are probably ok.
  18. keendean
    keendean Member
    358
    Just being a bit para, bought a few duff Subarus in my time.
  19. Ryanc
    Ryanc Active Member
    1,321
    Figures sound right for standard s3 in 2wd mode.
    Go on condition.
