S3 BBK Conversion
S3 BUH Aug 21, 2011
  1. S3 BUH
    S3 BUH Member
    355
    Hi guys and gals have been looking at a BBK for when i take the car to stage 2/2+.
    have read good things about AP, VWR have not seen any reviews on brembro are they still good?
    was recomended a forge set but can not find anything on these either anyone got experience with any of these kits?
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    Audi use Brembo on the R8, so I'd say they're probably pretty good! Didn't know Forge did brakes, so can't help there. I've just got my hands on R8 rear 4-pot Brembos with 362mm AP Racing 2-piece rotors... haven't fitted them yet so can't say for sure, but N8's warned me about wheel clearance. Not just the rotor fitting inside the drum of the wheel (mine should clear, but 18" and up only) but also the spokes clearing the calipers. Different set-ups and different wheels pretty much have to be tried individually, sometime needing spacers to push the wheel out from the hub.
    Bottom line - do your research, and look for people who have the same kit on the same car when getting recommendations. Luckily, there's quite a few guys on here with BBKs from a selection of manufacturers, so you should be pointed in the right direction no problems!
  3. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    AP racing kit is unbelievable. Still 100% balance. Hard pedal feel. Outrageous stopping power. They are quite simply stunning. Check my build thread for pics.
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    brembos are good, depending what ones you go for, just dont touch the TTRS ones as they are rubbish
    ive been in Rys S3 with his AP kit and they are quality! ive got VWR on mine and they are also fantastic, step on them hard and it will try and pull your face off!
  5. S3 BUH
    S3 BUH Member
    355
    yer i had never heard of forge doing a kit until a few days ago they do two
    Forge Motorsport | Alloy Fabrication
    if i put big brakes on the front do the rears need to be upgraded aswell ?
  6. jungleman
    2,035
    42
    forge dont make them, they are rebranded, but no one i know knows who originally makes them, and as no one is running them you would be very brave to try them and could end up wasting your money, so i would stick to tried and tested applications
    the backs are fine even with a BBK on the front as audi oversize the backs anyway so braking balance and control wont be made worse
  7. S3 BUH
    S3 BUH Member
    355
    was looking at these brembros there more expensive but brakes are something that it's money well spent IMO
    Brembo GT Brake Kit [1M1.8033.A] | S3 2.0T 8P Brakes | APS
    does anyone know if i would need rears to keep the balance with brembros as they do a rear kit
    Brembo GT Rear Brake Kit [2P1.6007.A] | S3 2.0T 8P Brakes | APS
  8. jungleman
    2,035
    42
    spending money on braking up to a point is good, but you can go to a point where your wasting money, my VWRs have taken everything ive thrown at them on stage 2 which includes very fast road use with repeated very heavy braking on country roads, to give you an idea, mine came off a 500+ bhp S3 that was used for fast road use and track use and neither me or the previous owner never had anything less then 100% confidence in them even after sustained abuse, although the brembo GT kit im sure is good, feel its a little expensive and as its twice the price of similar applications from VWR & AP, or even Alcon!
  9. S3RYE
    3,448
    70
    Paullie and Kelza like this.
  10. jungleman
    2,035
    42
    as Ry's doing show and tell lol...
  11. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    471
    73
  12. jungleman
    2,035
    42
    think a lot of the vauxhall guys use them, and from what ive read they seem to like them, but again dont know of anyone running them on an S3
  13. S3 BUH
    S3 BUH Member
    355
    nice Rye do you have to use 10mm spacers to get these to fit over the CH's ?
  14. S3RYE
    3,448
    70
    I already had 10mm spacers, But I think you need around 5mm for the CH to clear.
    Bit of a better pic of the BRAKES :wub:
    quattro81 likes this.
  15. Adam.
    Adam. Meow.
    662
    34
    Audi R8 rear's are a great kit.
    N8 and MartayMcFly like this.
  16. N8
    17,163
    718
    And don't I know it Adam :wub:
    MartayMcFly likes this.
  17. S3 BUH
    S3 BUH Member
    355
    R8 kit looks the nuts is it a straight forward fit or does he kit need adjustment ?
  18. Adam.
    Adam. Meow.
    662
    34
    All you do is unbolt the old caliper, bolt the bracket on, then pop the disk on then bolt the caliper to the bracket.
    Bleeding is a piece of **** too.
  19. N8
    17,163
    718
    The R8 kit IS the nuts :wub:
  20. drnutta
    drnutta Member
    372
    Hi Guys,
    I have the Alcon Advantage BBK and I have to say they are amazing... not to mention very light!
    Will take a piccy if you lot are interested.
  21. jungleman
    2,035
    42
    :sign_pics:
  22. S3 BUH
    S3 BUH Member
    355
    :sign_pics: +1
  23. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Totally agree! I had the Alcon Advantage Extreme brake kit on my Astra VXR and it was pretty amazing, great performance even when cold and not a single sign of any fade. Wasn't sure they did a kit for the S3 though. Only thing I'd say is that replacement rotors for the Astra anyway were very expensive at around £700 a pair :wub: x
    S3RYE likes this.
  24. N8
    17,163
    718
    Alcon are great brakes :wub:
  25. drnutta
    drnutta Member
    372
    sorry did not see this... will get pictures up ASAP... as its dark already :)
  26. N8
    17,163
    718
    Update: My R8 kit is up for grabs, will supply with brand new 350mm discs and new pads for £1000
  27. S3 BUH
    S3 BUH Member
    355
    very tempting maybe in 4-5 weeks when i have the money
  28. Adam.
    Adam. Meow.
    662
    34
    HMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
    If only I hadn't just bought a brand new set.
    :sob:
  29. N8
    17,163
    718
    Speak 2moro Adam
  30. S3RYE
    3,448
    70
    Nath what are you up to!?? :laugh:
  31. Adam.
    Adam. Meow.
    662
    34
    Gathering his pennies together :undwech:
  32. S3RYE
    3,448
    70
    in aid of!? :hubbahubba:
  33. N8
    17,163
    718
    Need to see if it'll come off first we shall see :ninja:
  34. S3RYE
    3,448
    70
    so are you sayin you could end up brakeless!? :scared2:
  35. kris@forge
    kris@forge Member
    42
    We manufacture the Callipers, Bells ,and mounting brackets in the Forge workshop on our CNC machining centres , The brake lines are produced in house by our sister company Hosetechnik and are TUV & DOT approved , we use EBC Redstuff pads , and we purchase the brake rotors from a manufacturer that also supplies two other leading brake manufacturers so the quality is assured.
    The price for these brakes are £1,044.00 exc VAT £1,252.80 inc VAT
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
  36. N8
    17,163
    718
    No I wont be selling the R8s till I know the upgrade will work - more for looks than breaking ability :wub:
  37. S3RYE
    3,448
    70
    look good tbh!! good price too!!
    :wub::wub:
  38. N8
    17,163
    718
    Love you more Ry! :wub:
  39. S3RYE
    3,448
    70
    :kiss:
  40. S3 BUH
    S3 BUH Member
    355
    bump! anyone running the forge kit ?
    have found two reviews on other sites for GTI's running them they really rate them anyone got them on a S3 though ?
