S3 APY Hunting at idle/cutting out
Bad Sir Culation Dec 23, 2013
  1. Bad Sir Culation
    Bad Sir Culation Member
    287
    17
    Since changing the plugs on Friday and also putting a different cone filter on to replace the tiny one it had on previously, I've now noticed this issue.
    Car sounds great and pulls brilliantly, but coming to a junction with clutch dipped and going into neutral, it hunts and/or cuts out. It also cuts out when I start it sometimes.
    I unplugged the maf and started back up, and it was exactly the same. I'm not hearing any misfires so don't think it's the plugs.
    Any ideas? Wondering if my moving things around in the bay has split a brittle hose or something.
    It's pretty confusing.....
  2. Goubo1
    Goubo1 Well-Known Member
    948
    278
    Check under the inlet manifold for leaks had this before and had a hose come of the inet the larger of the 3 hoses it was
  3. Bad Sir Culation
    287
    17
    Will double check.
    I also meant to mention that the temp gauge is intermittent. The coolant temp sensor has been replaced and this made no difference. Not sure if that would also have a bearing on this issue?
  4. willh92
    willh92 Active Member Team Brilliant Black Audi S1
    347
    56
    Had similar issues, I was adamant it was a split hose but couldn't find it at all! So took it for a scan, sure enough it was an air leak. £25 part, hope yours is an easy fix too mate! Get a scan done if you can find the problem!
  5. Wallm0nkey
    Wallm0nkey Member
    225
    My temp gauge was intermittent I had changed CTS but it would sit at 60 then on random days appear to work. Heater still worked as normal too new thermostat sorted it out has sat bang on 90 when warm since I changed the coolant while I was at it for the cost of it. The bottom bolt was a pain to get so if you do change it give your self plenty of light! Strangely a few days before I changed it an engine light had appeared because of it which has now gone.
  6. Bad Sir Culation
    287
    17
    Will deffo look into a new thermostat then. Is there one make I should look out for at ECP etc?
  7. Sean_S3
    Sean_S3 Member
    323
    17
    A genuine stat and coolant temp sensor are recommended on here mate. Ones from other places seem to be a bit hit and miss.
    My car is also cutting out on startup at the minute , needs a bit of throttle to get it going and once the revs level out it is fine. Bit of research on here points to the CTS which as luck has it I have a spare. Will be swappoing it over after christmas.
  8. Bad Sir Culation
    287
    17
    So even though I've changed the CTS, you think it's worth buying one from Audi and doing it again?
    With my BMW, you can buy the actual OEM stat at ECP. They just have the BMW logo filed off! :)
  9. Bad Sir Culation
    287
    17
    Thermostat was going crazy today. It ran right upto 90, but on the return journey it then dropped right down to 60. I hooked up my ELM 327 and ran Torque with it. No fault codes! I also looked at the real time temp on there and it was corresponding to the gauge, so I reckon it's in need of a thermostat for sure.
    The rough idle also seems to be an intermittent fault, which is bizarre with no codes.
    ALSO Torque said that 02 Sensor 2 was showing 0v. Anybody know which part I need to replace this one? I believe it's the post cat sensor?
  10. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
  11. Bad Sir Culation
    287
    17
    Cheers, but they list 3 Bosch items and there's no indication of which I want.
  12. Bad Sir Culation
    287
    17
    Anybody know?
