S3 apy engine rebuild help
Goubo1 May 28, 2013
  1. Goubo1
    Goubo1 Well-Known Member
    958
    298
    Going to try get my engine sorted out over the weekend,my mate that's going to be doing the work has asked me to find out if its hydraulic lifters ??
    he also said while the engine is out about doing the conrods and pistons what are the best conrods and pistons to go for on the apy engine ? anyone know where I could get some for Friday ?
  2. <tuffty/>
    21,967
    4,243
    Rods = Bill.... and yes, hydraulic lifters in 20vs... make sure your mechanic FOLLOWS the instructions for fitting them... ARP bolts aren't the same as the OE ones...
  3. <tuffty/>
    21,967
    4,243
    Why pistons???... replace the rings and do a hone for sure but no need for pistons...
  4. Goubo1
    958
    298
    does bill have them in stock tuffty ?,is their a guide for fitting them with the bolts or a thread on here ?
    if all goes well the work will be getting started on Friday night
  5. Goubo1
    958
    298
    its just incase there is damage to the ones I have tuffty
  6. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Rod bolts just follow a different torque sequence thats all. 3x 50lbs.
  7. Goubo1
    958
    298
    is that 50lbs then slacken back to 50 slacken and back to 50 Karl ?
  8. StaceyS3
    StaceyS3 Well-Known Member
    2,507
    506
    If your planning on changing pistons to anything other than OEM ones you will need to completely strip the block and rebore it
    I found ETKA and Elsawin really helpful software to have on your computer and can be had on many download sites ;)
  9. Goubo1
    958
    298
    Cheers for that mate,would pistons from euro parts be ok or best of going audi dealer ? It's just incase the pistons are have been damaged with what's happend
  10. Goubo1
    958
    298
    Is there a guide to a list of parts to what else to get when doing rods ?
  11. <tuffty/>
    21,967
    4,243
    I use 55ftlbs and yes, tighten then slacken, tighten then slacken and tighten for the last time... and by that I mean tighten both bolts on each rod then slacken both bolts on each rod in turn..
    No tutorials as such... this is engine building... your guy will hopefully have some idea... I have gone into it a bit of detail in my build thread before...
    Pistons won't need changing unless you have put a hole in them... if the valves have impacted them all you need to do is carefully flatten off the sharp edges to prevent hotspots from occurring and causing pre-ignition...
    New rings need to be gapped correctly and you NEED to hone the bore to bed them in... you will also need to run mineral oil for at least the running in period of 100 miles or so before dumping it and putting fully synth back in
    New shells needed too... Bill will have those... you will also need to check the small end clearance on the gudgeon pins... you may need to hone them a little... the pins need to slide in the small ends... if they bind then no oil can squeeze past to lubricate the pins or bush and you will end up with small end rattle...
    Also advised is a new oil pump and pick up pipe..
    ... but then hopefully your guy knows this...
  12. Goubo1
    958
    298
    thanks for the pointers tuffty,I will have a good look threw your thread mate
    is there any special tools required or would a garage have most of the tools needed ?
    the plan is to replace as much as possible like all gaskets,oil pump pick up pipe and such while the engine is out that's why the rods are getting done to as it would be a shame not to when the chance is there
    i will give bill a ring tomorrow and explain what's getting done and he will know the parts I need to order from him
  13. superkarl
    9,623
    2,488
    Do you have a budget btw?
    I did mine on a bit of a budget, i say a bit because its still bloody expensive.
    I sourced oem 9.5 comp pistons for mine, and all the rest that goes with it.
    Had i another 5-600 quid, id have loved to taken the block to 83mm and got some high comp CP pistons or similar.
    Something to consider.
  14. Goubo1
    958
    298
    I could go to 2k but that's leaving me on the skin of my **** but desperate to get it back on the road mate,am I right in thinking its only rods that's needed for 400bhp ? As I would like to do it so I have some head room for further mods
  15. superkarl
    9,623
    2,488
    Are you utilising your current turbo? K26??
    Im not sure i follow with that question? Only rods needed for 400?
    What i meant by my previous post is that, if your going to do it, even only rods, which will be atleast 1k, and thats assuming your mechanic is v friendly. Then you may aswell do what ever you can, its an investment in your hunger for power, so what you do with this build, can help you in the future should you want more power and change turbo.
    Hell, ive not even finished mine and i kick myself for not going 83mm pistons, just so its done ready for anything else i might want to add years down the line. I.e. Stroker crank.
    See What i mean.
    If you just want your car back on the road asap with rods so you can enjoy what youve got, sure go ahead and do the basic minimum.
  16. Goubo1
    958
    298
    It will be with the k26 for now mate ,what I mean if the engine gets sorted and get the rods done would be enough to support 400 with the right turbo injectors etc etc
    Yeah I see what you mean mate but with the rods done the and with the k26 all else I would plan on doing is a custom map and leave it at that as I couldn't afford anything else for a long time
    im wanting to do the basic minimum but also do what's sensible to while the engine is out like oil pump and pick stuff like that as tuffty said
  17. superkarl
    9,623
    2,488
    With rods, bearings, rings and all the pumps n gaskets and what no then the motor should easily take 400hp and similar torques.
    so you can be confident that what youre doing should last you. And of course will be a great basis should you ever change the k26 for something bigger.
    Good luck with it anyway. Im sure everything will be sweet.
    Goubo1 likes this.
  18. Goubo1
    958
    298
    cheers pal,fingers crossed it will be all good :)
  19. StaceyS3
    2,507
    506
    May be worth dropping dan (beachbuggy) a line and getting him to work his magic on yours as could probably extract a reasonable amount more out of it with a billet wheel and of coarse its cheapest and easiest to do whilst it's already out ;)
  20. Goubo1
    958
    298
    as much as a would love to mate I couldn't afford it just now by the time I buy all the parts I need and hoping to have it back running for Monday morning fingers crossed
  21. Goubo1
    958
    298
    Got the car looked at today and one of the pistons has a hole in it my mate recons it's either melted a piston or dropped a valve part of the plug was smashed and metal from the plug has went into the cylinder,so I'm going to try get another engine
  22. superkarl
    9,623
    2,488
    Sounds like youre as lucky as me :(
  23. Stuart35205
    Stuart35205 Member
    108
    Not the best news to find out if you want it bk by Monday , good luck anyway mate
  24. Goubo1
    958
    298
    it won't be back for many Mondays now mate
  25. Goubo1
    958
    298
    its a total pisser mate so it's back to the drawing board now
  26. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,013
    11,151
    Sorry to hear about the car Robert. Im sure you will get it sorted out real soon, it be a shame not to see it running again. Drop me a pm when your up and running and i will give you some details of a very local meet with some of the others in our area that im going to organise. Fingers crossed for you. Will be strange when im passing by and the car nit sitting in its usual spot. :) x
    superkarl likes this.
  27. Goubo1
    958
    298
    it will be back eventually just keep a look out :) x
    Sandra likes this.
