S3 Alarm Problems - Fault codes & video.
Greig300 Jun 6, 2012
  1. Greig300
    Greig300 Member
    253
    In the last month my Audi S3 upon starting intermittently would beep from the rear 2 - 3 times. After 2 weeks or so after hearing the beeps i can now hear from the Subwoofer an electrical noise which can be heard from outside and inside the car. Even when turned completely off and locked it can be heard. Now the noise happens when driving and about 5 seconds after locking the car. I've been told it can be the central lock pump... the parts inside break/shatter or can leak. All the door locks work perfectly fine manually and from the key fob. Long before hearing any beeping noises and clicking noises opening the rear boot would make the boot lights flick on & off real fast and make relay type noise. Now i think all of these faults lead into one thing. Also the Alarm comes on intermittently. Another common fault is the battery for the alarm. Am confused...
    Video of noise:
    S3 subwoofer - YouTube
    Fault codes:
    VCDS-Lite Version: Release 1.1
    Wednesday, 06 June 2012, 16:58:48.
    Control Module Part Number: 8D0 862 257 E
    Component and/or Version: CV-Pump, Alarm, RC D17
    Software Coding: 15178
    Work Shop Code: WSC 06435
    VCID: 2F1190BFFE13
    11 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01370 - Shareware Version. To Decode all DTCs
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01373 - Shareware Version. To Decode all DTCs
    01366 - Shareware Version. To Decode all DTCs
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Shareware Version. To Decode all DTCs
    28-00 - Please Register/Activate
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    01134 - Shareware Version. To Decode all DTCs
    49-00 - Please Register/Activate
    Any help or guides to fault finding would be great.
  2. Greig300
    Greig300 Member
    253
    Anyone?
