S3 akm clutch
Discussion in 'A3/S3 Forum (8L Chassis)' started by Yicker, Sep 22, 2012.
  1. Yicker
    Yicker Member
    May 26, 2012
    30
    Hi all ;)
    Im sure i felt my clutch slip slightly a couple of times on the way home from work this morning :(
    Just having a quick nosey online and found this AUDI S3 SOLID MASS FLYWHEEL SPORTS CLUTCH KIT & BEARING | eBay
    Would be any good or am i better of sticking with a standard kit? Would i need to replace the dmf or would i get away with it if i stay standard?
    Cheers,Tony
  2. Advert Guest Advertisement
  3. moredoor
    moredoor Member
    Aug 22, 2011
    160
    Once the gearbox is off you can check the state of the flywheel, but yes you'll always better off in the long term replacing the DMF when doing a clutch.
    That ebay flywheel looks ok but I have a thing about clutch kits that have been painted RED on ebay, most of the time they're s**t.
    Maybe someone here has used this kit and will be able to give you more info.
  4. superkarl
    superkarl MAN OF STEEL
    Mar 28, 2010
    9,101
    2,154
    AVOID.
    just do a quick google search on techniclutch to see why
    moredoor likes this.
