S3 ABS system rubbish ????
ex_scoobydoo Dec 20, 2009
  1. ex_scoobydoo
    ex_scoobydoo Member
    179
    we have got some bad snow here at the moment, the roads are really bad, but my brakes seem a load of rubbish, the slightest touch and the abs starts banging away but i still seem to be out of control, ive had some near misses over the last couple of days were i have stopped just at the last second, i hardly touch the pedal and the abs kicks in but i still seem to slide and skid.
    im a bit nervous driving down hills now it just dont feel safe at all.
    is everyone elses like this ?
  2. nath
    nath New Member
    27
    yeah not a very good system ive had to put in reverse a couple of times as the brakes were doing nothing
  3. ex_scoobydoo
    ex_scoobydoo Member
    179
    ah at least its not just me :)
  4. ikbenben
    ikbenben Belgium S3 driver
    105
    That's completely normal.
    A non-abs car stop quicker in the snow then an abs car ;)
  5. ex_scoobydoo
    ex_scoobydoo Member
    179
    when abs is working is the abs light on the clocks ment to come on or only when the ignition is first turned on it shows
  6. ikbenben
    105
    Only briefly when you turn on the ignition.
    If the light stays on then there is something wrong with the abs.
  7. Broken Byzan
    Broken Byzan Photographic Moderator Staff Member Moderator VCDS Map User Audi A4 quattro
    13,246
    468
    ABS is awful in the snow FACT. Makes no difference you have an S3 sadly. Brake earlier and gentler and the ABS won't need to try and interceed
  8. A3Tom
    A3Tom Smell my finger.
    3,504
    Indeed, when I was in Canada for a winter we had ours turned off as it was pure ****!.
    Shame you dont have the option to switch it off for the 3 days a year its useless here ;)
  9. <tuffty/>
    22,268
    4,415
    Slippery snow + wide wheels with sport tyres = ABS on acid... simples...
  10. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Dont use your brakes then. I can get to work almost without touching my brakes and I live 500ft above where I work. Engine braking is where its at.
  11. A3Tom
    3,504
    Yep!!
  12. 5ean
    5ean S3 Owner VCDS Map User
    415
    What MintyS3 said.. Engine breaking is key in the snow.
  13. chancer
    chancer Member
    114
    Absolutely spot on.
    There is nothing wrong with the ABS, you need to modify how you drive in severe conditions. Unfortunately many drivers don't and then wonder why they end up coming to grief.
  14. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I when out last night in it and yes the ABS is rubbish lol. Did anyones exhaust note get louder. Was getting some nasty vibrations as if my exhaust was knocking or in half.
  15. ex_scoobydoo
    ex_scoobydoo Member
    179
    sleet and snow hitting under the car maybe ?
  16. ex_scoobydoo
    ex_scoobydoo Member
    179
    i have drove in these conditions many of times, the abs on the audi is a lot worse than other abs cars i have drove in snow, 5mph using the gears to slow 1st and 2nd, the dam things still work no better, you can not go down a steep decline with bends and not have to touch the brakes, the car picks up its own momentum, you end up going faster than you would using the brakes, very nerving, and it takes a lot to panic me when driving :)
  17. Westy
    Westy Well-Known Member
    17,443
    1,106
    I'm not 100% sure how FWD cars ABS works but the Audi detects everything via its 4 wheel speed sensors. If a FWD car only uses the activity of the front wheel then that maybe why the Quattros are more sensitive!
  18. S3 Nattie
    1,599
    Ye I think so, well hope so. It was fine on dry roads but every now and then would sound as if the exhaust was in half. It only ever happened yesterday in the snow and wondered if anyone else has experienced something similar.
  19. Westy
    17,443
    1,106
    Only thing i'd experienced was funny noises from my suspension when going over speed bumps. I think it was where snow and ice had flicked up into the springs and shocks!
  20. S3 Nattie
    1,599
    It was only making the noise in thick snow so I think it something to do with that. Sounded normal otherwise.
  21. Westy
    17,443
    1,106
    In which case I wouldn't worry about it too much mate.
