S3 8P Exhaust Help (Suggestions?) - Miltek Non Res
JonDogg Oct 19, 2013
  1. JonDogg
    JonDogg New Member
    27
    Hi Guys,
    I have a DSG S3 with Revo Stage 1, Evoms Intake, Forge DV
    Im looking at getting a new exhaust so I can take it to Stage 2 shortly, I am a bit confused really.
    Do most of you guys on here running exhausts use sports cats / decats? Its easy finding Exhausts with Catback but it seems hard to find sports cats by themselves, and they also seem super expensive.
    Is it a bad decision to just get the Miltek Non Res Catback exhaust for now, and by a cat after (when I can afford it!)?
    Im looking at buying this one: S3 MILLTEK EXHAUST MK2 2.0 TURBO NON RESONATED 3 DOOR CAT BACK SSXAU123 | eBay
    Does anyone know the powergains for this too?
  2. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,939
    500
    cat back doesn't add much power if any. the biggest restriction is in the downpipe. i would also suggest you to take look at the bcs power valve system. if i didn't have milltek on my car i would probably go for it as i like the option to keep it quiet or loud when you want it.
    some member have fitted milltek downpipe with oem cat back and have seen some gains.
  3. JonDogg
    JonDogg New Member
    27
    so you would recommend really that i just upgrade my whole system when i get the chance too?
    is the downpipe / decat hard to fit yourself?
  4. S.
    1,939
    500
    yes, as you will probably go stage 2+ soon after stage 2 (it would be silly not to especially in s-tronic).
    i've fitted compete milltek system. then i got fuel pump and went stage 2+ :D
    well i think you should need the lift for fitting as you need to take of the front end of the propshaft so you can get to the downpipe bolts.
  5. S.
    1,939
    500
    there's turbo back milltek for sale at classifieds for a little more than that on ebay :D
  6. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    571
    We fitted a full BCS system to 1 of the boys on heres S3 today and it sounds very nice indeed...
  7. STYLEZAU
    STYLEZAU Member
    47
    Wait and upgrade to Stage 2 Turboback straight away. Will be cheaper in the end and defo worth it!
  8. S3Alex
    10,373
    4,414
    As STYLEZAU has recommended,it's probably cheaper in the long run to wait and get the entire system.
    You don't need a decat until you buy a big turbo.
  9. nluk100
    nluk100 Active Member
    881
    160
    43
    I fitted an MV Sports dp to my OEM cat-back and got good torque gains (+60Nm) and the car pulled better from low revs. I added a Milltek cat back later and there was some improvement but nothing to shout about. If you're looking for more than 340ps then you'll need the cat-back.
  10. pablo
    pablo Active Member
    985
    60
    anyone got a decat downpipe and had a sports cat welded in? you can get a universal sports cat for around 80-100 quid on ebay.
  11. RedDejavu
    RedDejavu Well-Known Member
    1,788
    333
    First of all remember that stage 2 is just rubbish due to fueling problems that ppl experience, you will need a more efficient fuel pump or at least upgraded internals. Low end gets less torque and power than stage1 and common problem is fuel rail pressure drops 3-4k making boost problems, turbo/shifts lag etc. You have 2 options now stay stage 1 and fit TBE with 200 cell sports cat or just jump straight to stage 2+ which I recommend.
    S3Alex likes this.
  12. S3Alex
    10,373
    4,414
    Very good advice.
    The stock HPFP does not flow enough fuel in the midrange regions,and the result is a big drop in torque....from APR's site,they state that the stock pump can only support 158bhp @ 3000rpm,whereas all of the aftermarket pumps will supply well in excess of that.
    I've long thought that Stg2+ is the best value upgrade to the S3.
  13. Gfermer
    Gfermer Active Member
    454
    72
    Hhhm glad I had a look at this post I've currently for tbe miltek and Revo intake Ben at shark has put a custom stage 1 on at the moment as my plans were stage 2 but have to wait till I save for clutch so he has toned it down a bit to save the clutch in the meantime, so my question is am I wasting my time with getting it proper stage 2 then? What's all needed for stage 2 plus and how does the car cope with it all? Don't want to go to far with car as I am already planning clutch and flywheel best year along with coilovers. Anti roll bars and was thinking of maybe upgrading my brakes in some way, sorry to hijack the exhaust thread
  14. RedDejavu
    1,788
    333
    stage 2 - ECU, intake, TBE
    stage 2+ - ECU, intake, TBE, HPFP (APR,LOBA)/upgraded internals(Autotech)
  15. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I had a Turbo back Resonated Milltek fitted (already had Stage 1 map) and it made a big difference.
    Aside the quality issue I had it really did do what it said on the tin performance wise.
  16. kimhemm
    kimhemm Member
    66
    At stage 1 I would say the options are :
    1 : HPFP upgrade and stage 1+ (will give you a lot more power in the middle range especially and I think around 335 HP)
    2 : Just a DP with OEM catback and stage 2 (will give you the same power as stage 1+ but with less power in the middle range)
    3 : Save your money for DP and HPFP and go 2+
    Remember that stage 1+ or 2+ will put more stress on your clutch and depending on your driving style it CAN begin to slip. Not saying it will, but it is something to be considered if money are tight for upgrades
    Catback is not really for a lot more power but for the sound. Most important on the exhaust is the DP
  17. pablo
    pablo Active Member
    985
    60
    whats the restriction on the DP? the oem cat or the pipe itself?
  18. kimhemm
    kimhemm Member
    66
    You have two OEM cats, one RIGHT after the turbo.
    One is 600 cell and the other is 800 cell. I have seen people taking off the OEM DP and cleaning out the first cat and running that with some power gains but I would't really bother just get a good DP with a race cat
  19. pablo
    pablo Active Member
    985
    60
    they are hugely expensive though. was wondering could the precat get gutted and the std cat chopped out and a universal 200cell cat put in.
    no idea if it would satisfy the ecu or not though.
  20. RedDejavu
    1,788
    333
    I wouldnt say its expensive and worth the hassle. IM going to sell mine Milltek soon for 600 and its full TBE resonated.
  21. turbonutz
    turbonutz Active Member
    421
    61
    i fitted the bcs sport exhaust the other day, wow what a sound of that, and what a lovely looking peice of kit to, was easy job reall, hardest thing was moving the prop shaft out the way.
    hmmm so red you think stage 2 bad idea even as a stop gap? because i dont fancy forking out money for a new clutch the now aswell as a fuel pump?
  22. RedDejavu
    1,788
    333
    Not sure how shark is mapping stage 2 but as above stage1+ will be faster and more driveable. I felt the car more laggy and gutless mid range running stage2.
  23. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    341
  24. turbonutz
    421
    61
    hmmm i was thinking of getting the stage 2 done cus its recommended with the sport exhaust hmmm might just go pure daft and buy clutch and fuel pump aswell as planned braked an wheels, boom 4 grand there's yer dinner
  25. Gfermer
    454
    72
    I'm in the same position as you now turbonutz I currently have custom stage 1 that Ben done at shark I was planning on clutch next year along with suspension and maybe brakes upgraded then was gonna get stage 2 but after chatting with reddejavu Im considering fuel pump as well prob chat to Ben and see what he thinks might just get it and stage 2 Map then decide from there if I want to go more
  26. Banjo789
    Banjo789 New Member
    My exhaust has just started blowing. Where the down pipe splits into a 'Y' it's coming out of the flexi tubing on the one side. It passed the MOT as advisory, but they quoted £672 + VAT for the part from Audi! I've got a stage 1 map (Bluefin) and a new clutch, so it looks like I'm on the lookout for a second hand Miltek turbo back (Cat & Res) for a 3dr. If I have problems with fueling then its a new fuel pump. I can see this getting an expensive habit.
    turbonutz likes this.
  27. S.
    1,939
    500
    there's turbo back in classifieds :D
  28. RedDejavu
    1,788
    333
    Give me a shout mine is 3dr Resonated:] Problem with stage 2 is that the mapping in most cases requests more fuel than could be delivered. From what I read REVO requests too much pressure/fuel mid range therefore most people are having fueling problems once running stage 2 program.
  29. nluk100
    881
    160
    43
    Not worth it on the S3 due to some very severe restrictions in the design - needs new pipework unfortunately. Gutting the pre-cat will make a bit of difference but it's a bad design to start off with.
  30. pablo
    pablo Active Member
    985
    60
    hmmm that sucks alright. how about a decat downpipe with a 200cell cat put in. I cant understand the huge price increase if you want a cat version of the downpipe (500-600 quid iirc?)
    Also - I see a lot of the downpipes are 3" - does this mean they need a reducer to work with std catback?
  31. PaulAr
    PaulAr S3 (8P)
    4,073
    186
  32. turbonutz
    421
    61
    Same One for 375 on vagoc but the lambda sensor fitting need retapped. (Easy fix)? A woulda got this if I never got ma bcs already haaa
  33. Silky-S3
    1,407
    341
  34. Adz85
    Adz85 New Member
    15
    I would suggest looking at powervalve.co.uk before choosing, It was recommended to me and I am soooooo glad I went with it. The system is amazing if you don't want that droning noise all the time + I believe it played a big part in getting my s3 to 400bhp on a Revo Stg2+ map. You get what you pay for. The fitters even said it was a pleasure to install (and if you ask any Mech, that is a rare thing) Once you come on boost the active valve opens allowing the exhaust gasses to bypass the rear box, then it really comes alive 😃
