S3 8P cruise control retrofit - engine won't code
davF Feb 16, 2014
  1. davF
    davF ibiza cupra 177bhp
    10
    After fitting the retrofit parts yesterday, today I went to get it coded. Steering control module coded fine but the engine wouldn't code?
    Few screen shots:
    ** standard coding**
    https://dl.dropboxusercontent.com/u/28079959/step1.png
    **cruise control selected**
    https://dl.dropboxusercontent.com/u/28079959/step2.png
    **current vs new coding**
    https://dl.dropboxusercontent.com/u/28079959/step3.png
    ** FAIL - error message**
    https://dl.dropboxusercontent.com/u/28079959/step4.png
    Looks to be that the equipment number is too high and not in range but this couldn't be altered.
    Anyone able to shed some light on this?
  2. davF
    10
    Car in question is a 2011, so the wire isn't required I'm led to believe.
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Suggest you contact NHN as he's our resident in house coding expert; go to his section in forum sponsors.
  4. davF
    10
    Fired him a PM hopefully he can assist :) thanks
  5. davF
    10
    Anyone else got any ideas?
  6. NHN
    29,327
    1,708
    Are you doing with engine on or off, making sure ignition is on.
  7. davF
    10
    Engine off, ignition on.
  8. davF
    10
    What do you think with regards to the equipment number range etc?
  9. davF
    10
    Tried another vcds still the same, would a remap cause the equipment number to be out of spec. Revo remap?
  10. TillA
    TillA Member
    41
    Isn't this the issue that you had with mine Nigel with the number being too high?
  11. NHN
    29,327
    1,708
    Remove vcds, delete the vcds folder in c: drive, then restart machine, install vcds, then plug cable in, test on car & select save, then go into options area, then user tab & make sure its set as zero's for wsc etc then test.
