S3 (8P) cat-back exhaust
Ginger Prince Mar 10, 2014
  1. Ginger Prince
    Ginger Prince Member
    189
    Hi all,
    Im changing my car (57 plate S3) to a 2011 S3 Sportback.
    2 years ago I put a Milltek (cat-back) exhaust on the current car and would like to swap it onto the new one.
    Does anyone know any scrap yards and/or contacts in the Manchester area re me getting a used cat-back to put back on the S3 Im selling.
    I don't want to pay much as the car is going & I'm already going to have to pay for the removal & fitting of both systems.
    Thanks in advance
    Mike
  2. nluk100
    nluk100 Well-Known Member
    1,097
    206
    Are you going from Sportback to Sportback, as the 3dr system is different?
  3. Ginger Prince
    189
    No, my current S3 (8P) is the 3 door but i wanted to change the Milltek cat-back onto the 2011 Sportback.
    Is it different and as such not possible...?
  4. nluk100
    1,097
    206
    The Sportback exhaust is longer, you will need the MSAU428 rear box to replace your MSAU347 rear box on the 3 door. Unfortunately it is the most expensive part @ £304+VAT.
  5. Ginger Prince
    189
    Noooooooooooooo :(
    Looks like it wont be getting swapped after all then....
    Cheers for giving me the heads up pal
  6. MattS5
    MattS5 Active Member
    619
    60
    Still worth taking it off and selling it?
    Must be worth £250.
    You should be able to pick up a used OEM cat back for £50 I'd have thought. (maybe PX with whomever buys yours?)
    That's a balance of £200 towards the next Milltek for the sportback.
  7. Ginger Prince
    189
    I don't know any scrappers though to pick up a used/cheap OEM back box....
  8. MattS5
    619
    60
  9. Matthaden
    Matthaden Member
    30
    I have a standard three door back box for sale :) and im only about 30 miles south of manchester!!!!!
  10. Matthaden
    Matthaden Member
    30
    Mine is off a 2010 model though not sure its the same
  11. Ginger Prince
    189
    Cheers boys!
    Don't wanna be paying £50 for a used exhaust which I'm only putting on to sell and as I've been told the Milltek on my current 3 door S3 wont fit the Sportback o may just bite the bullet & leave it....
  12. Matthaden
    Matthaden Member
    30
    You could get a good fabricator to cut the tips of your current one and extend the tailpipes a couple of inches as i believe that is the only difference but just check first. You dont want to be shelling out another £400 for a new miltek do you?
  13. Ginger Prince
    189
    No i don't mate, I'm gonna be on my **** with the new one but pretty clueless re chopping exhausts....
  14. Matthaden
    Matthaden Member
    30
    I would be tempted to ring Miltek and ask them exactly what the difference is between the 3 door and the sport back models then you will know for sure if it is a possible cut and shut im sure you could find somewhere to get that sorted for you
  15. Ginger Prince
    189
    Thats a good idea, i'll drop them a line tomoz!
    Cheers Matt and fingers crossed....
  16. Matthaden
    Matthaden Member
    30
    Good luck!!
  17. Muzza80
    Muzza80 Well-Known Member
    700
    337
    Easy fix the tailpipes just need to be extended about 70mm, any exhaust place should be able to sort it for you cheap.
  18. Ginger Prince
    189
    This is the response I got back from Milltek :(
    "The 3 and 5 door sport back share the same parts expect for the rear silencer so it will not be a direct swap.
    The 3 door rear silencer is much shorter on both the inlet pipe and the tailpipes so will not work on the 5 door sportback models."
  19. OliS3
    OliS3 Well-Known Member Team Sepang Audi S3 DSG
    872
    731
    93
    If you're looking to the sell the Milltek exhaust let me know :)
  20. Muzza80
    700
    337
    I think Milltek have given you duff info.
    The only difference is the tailpipes are about 70mm longer on the SB, I've looked into it myself.
    Any decent custom exhaust place should be able to extend them for you for a small fee.
