S3 8L Xenon headlights - Why has one turned darker/more yellow than the other?...
Benjiman46 Feb 19, 2013
  1. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Hi everyone,
    Quick few questions... I've got an 8L S3 with Xenon headlights and one of them has turned a yellow-ish colour... Pretty much the same colour as a normal halogen bulb. It's only on one side, I've got no other bulbs out or anything like that and the other "good" light is still as blue/white as it always has been.
    -Who has had this problem before?
    -What causes this?
    -How do I fix it?
    Cheers :)
    Ben
  2. BENJAMIN
    BENJAMIN Active Member
    503
    93
    You need a new bulb mate. When the hid bulbs are nearing the end of their life they turn a strange colour until they finally burn out. Would be worth buying a pair of bulbs because if you replace one, chances are the other one would look 'yellow'. Buy a pair of eBay, the bulb type is d2S and colour is 4300k standard.
    Benjiman46 likes this.
  3. Benjiman46
    551
    24
    Nice one mate :) cheers for your help :)
  4. superkarl
    superkarl MAN OF STEEL
    9,430
    2,399
    And opt for phillips or osram, not cheapo ebay ones. Get what you pay for and all that.
    About 30 quid for phillips ones on ebay
  5. BENJAMIN
    503
    93
    Phillips ones are original fitment and last aaaaaggggeeeessssss.
    OPENM2KE likes this.
  6. AVLO
    AVLO Active Member
    295
    52
    Iv just got this happen to me mate looks like a new HID kit is in order
  7. Benjiman46
    551
    24
  8. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    Wow that's cheap. I'm tempted to get those 6000k ones just so I can prove to my self why I want to stick with the OEM 4300k.
    Chavtastic! :thumbsup:
  9. Gops
    3,198
    666
    Get some Phillips 85122 CM's. those are bad boy ;)
  10. epox
    epox Active Member
    772
    74
    got even cheeper ones from flebay were around £6 the pair from china, have been using them every day since november!! just your luck i suposse. that was inc postage!!
  11. Adam P
    Adam P Active Member
    539
    178
    43
    Iv got a set of these to fit at the weekend aswell. I believe its a "Bumper off Job" isnt it?
  12. vfr800
    773
    57
    woah I got some £3.99 6000k bad boys from Hong Kong lol can't wait to try them out.
    er ... To change the bulbs you can try removing the cover on the back of the headlight. It shouldn't take more than two minutes.
  13. Adam P
    539
    178
    43
    er ... To change the bulbs you can try removing the cover on the back of the headlight. It shouldn't take more than two minutes.[/QUOTE]
    Swear i had read on previous threads that the bumper had to be removed to get the headlights out to change the d2's. :think:
    Oh well, makes it much easier for me. Will have them in tonight if that's the case.
  14. AVLO
    AVLO Active Member
    295
    52
    I cant use them bulbs now ben as iv changed from the pre-facelift xenons to the facelift a3 non-xenon's. Im in need of a full hid kit :-(
  15. vfr800
    773
    57
    To remove the facelift headlights you do need to remove the bumper, but the bulbs can be accessed easily by just opening the bonnet.
    If you have all the self levelling gubbins, which you should do as you had OEM HIDs, I'd just get an H1 type HID kit and stick it in your non-xenons. (I'm assuming the dipped light is a H1 on the non-xenons)
    It will cost you £40-£50 for an HID kit ... and you should be sorted, especially as you already have the mountings for the ballast etc.
    I've taken apart and rebuilt several Xenon and non-xenon units and the only difference, that I can perceive, apart from the ballast and the extra cable holes, is the projector's bulb holder/reflector.
    Liam
  16. Nilz
    11,329
    876
    Guys, you dont need to remove the bumper to change the bulbs, it can be done from the bonnet...you may need to move the battery back a little to get to the one on that side.
    Also make sure you dont touch the bulb if possible and make sure they are secured in properly as they can be a bit fiddly.
  17. grahamshaw
    grahamshaw New Member
    I have the same issue i changed the bullb no difference i also have changed ballast unit still no better
    cheers graham
  18. vfr800
    773
    57
    Is it one or both headlights that aren't working? Checked fuses and/or headlight switch?
  19. grahamshaw
    headlights are working but passenger side looks yellow
  20. vfr800
    773
    57
    Get some new bulbs then.
