S3 8L wheelbase dimensions
John-H Mar 5, 2010
  1. John-H
    John-H Member
    35
    Does anyone have dimension informations for the Mk1 S3 8L? Namely wheel base length and front and rear track? There should be an Audi drawing of car dimensions somewhere. Thanks.
  2. John-H
    John-H Member
    35
    Found this on another website:
    2002 Audi S3
    Wheelbase 2519 mm
    Track front 1527 mm
    Track rear 1503 mm
    Length 4159 mm
    Width 1763 mm
    Height 1415 mm
    Kerb weight 1423 kg
    Fuel capacity 62 litres
    Drag coefficient 0.335
    General
    Manufacturer Audi
    Model S3 Quattro 2002
    Powertrain Layout Front Engine / Full-Time 4WD
    Base Price Not Available
    Dimensions
    Length 4159 mm / 163.7 in
    Width 1763 mm / 69.4 in
    Height 1415 mm / 55.7 in
    Wheelbase 2519 mm / 99.2 in
    Weight 1420 kg / 3,131 lbs
    Front /Rear Track F 1527 mm / 60.1 in
    R 1503 mm / 59.2 in
    Engine
    Configuration 1.8 Liter Inline 4
    Valvetrain DOHC 5 Valves / Cylinder
    Displacement 1781 cc / 108.7 cu
    Power 167.8 kW / 225.0 bhp at 5900 rpm
    Bore 81 mm / 3.2 in
    Stroke 86.4 mm / 3.4 in
    Compression Ratio 9:1
    Bhp / Liter 126.33 bhp
    Redline Not Available
    Classis & Body
    Body / Frame Fully Galvanised, Unitary Steel Body w/
    Steering Maintenance-Free Rack & Pinion w/ Power Assist
    Brake Type Dual Circuit Brake System w/ Vented Discs, Diagonal Split, Electronic Stability Program (ESP), Electronic Brake-Force Distribution (EBD), Brake Servo & ABS
    Brake Size F 312 mm / 12.3 in
    R 256 mm / 10.1 in
    Wheels F 43 x 19 cm / 16.9 x 7.5 in
    R 43 x 19 cm / 16.9 x 7.5 in
    Tyres F 225/45R-17
    R 225/45R-17
    Transmission
    Gear Type 6 Speed Manual
    Final Drive 4.2:1
    1st Gear Ratio 3.42:1
    2nd Gear Ratio 2.11:1
    3rd Gear Ratio 1.43:1
    4th Gear Ratio 1.09:1
    5th Gear Ratio 1.1:1
    6th Gear Ratio 0.91:1
    Performance
    Top Speed 243.0 kph / 151 mph
    0 - 62 mph 6.6 seconds
