s3 8l revs slow to drop on gearchange
s3welshy Jan 28, 2013
  1. s3welshy
    s3welshy Member
    60
    Hi all.
    i have a 1999 s3 8l and the revs seem slow to drop, is this normal? i have also noticed its got worse on fuel, getting about 22 mpg.
    temp gets to 90 and stays there,
    any ideas?
    thanks.
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Not to sure on all your questions but the temp should stay at 90 when the card warmed up so that sounds normal anyway.
  3. Essflee
    Essflee Well-Known Member
    2,154
    67
    Need a new clutch switch by the sounds of it, common problem on our cars, the switch is located down by the clutch pedal. The temp is fine.
  4. dancuz
    dancuz Member
    140
  5. <tuffty/>
    21,885
    4,204
    Dual mass flywheel is heavy and revs don't drop fast... clutch switch can be tested in VCDS and will throw a fault code if faulty anyway so check that before replacing...
  6. s3welshy
    s3welshy Member
    60
    cheers all. just tryed in neutral and seems about the same. must assume its the dual mass flywheel as mentioned.
    thanks again.
