S3 8L Replace door speaker Bose
spiker May 8, 2010
  1. spiker
    spiker usually growling at something
    200
    HI
    Worlds worst car mechanic so looking for a guide on replacing the front bose speaker as its blown
    Anyone have one - or describe the process ?
    Is the job relatively straight forward ?
  2. spiker
    200
    set up email alert
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    First lower the window, then remove the 2 visible screws at the top on either end of the door card, remove the single screw inside the grab handle, push down the plastic cuff inside the grab handle and remove the 2 main screws behind it. Pull the whole door card straight up and out, but not too far as you need to unhinge the door release cable and unplug the wiring looms.
    Bose front speakers for an 8L are pretty rare on ebay but they do come up. Are you sure it's the speaker and not the amp, as the amp is more prone to failure, usually a dry solder joint on the PCB. If the tweeter still works OK then it's the speaker, but if the tweeter crackles as well then it's the amp as they both run off the same channel & wiring.
  4. spiker
    200
    Thanks Andy
    I ordered the speaker earlier today from Audi (£107) so I had best go and check the tweeter - although its ordered now ;(
  5. spiker
    200
    Phew
    Tweeter seems fine ;)
    Thanks again for the guide
