S3 8L feels down on power - most options tried.
gussy1 Mar 31, 2010
  1. gussy1
    gussy1 New Member
    Hey,
    Right, I bought my 8L 2 weeks ago. It has an APR chip in it. On the drive home it felt fantastic - bags of power and a surge of torque at 2800 rpm.
    Then near home I noticed a new found hissing / whooshing/ sucking noise from the engine bay. The car definitely felt as if it lost power and torque.
    I took it to a specialist and he did a smoke test. No problems he said. He cleaned out my MAF and cleaned out and pulsed my N75 valve. The car definitely felt quicker but it's still not as quick as it was - mainly it's not giving that huge power surge at 2800 - it's more of a long, smooth push of power as apposed to the rapid boost rush like before, even though it's still very quick. Hard turbo rush seems to be about 3500 now.
    Nothing came up on the VAG-com apart from the oxygen sensor heating element beginning to fail and he even said my car feels like a chipped S3 should.
    Coil packs were changed. Car is 2001 and only has 52,000 miles.
    Maybe I'm imagining things but the car certainly seemed to boost quicker before this odd noise came about.
    Any ideas?
  2. finesse
    finesse Active Member
    2,805
    Split hoses, pipes etc?
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Seems like you've carried out relevant checks which is a good start. Are you sure you're not just being paranoid now? lol
  4. sportquattro
    sportquattro Active Member
    835
    51
    Have you had it on VAG-COM and logged the airflow? should be around 205gs or more on a mapped engine, also check block 115 for demand boost vrs actual boost.
    Hope this helps
    Nige
  5. spiker
    spiker usually growling at something
    200
    If its APR - did it come with cruise control - check the settings , you may be in stock mode not chipped mode
    PM me if you are unsure
