S3 8L facelift - mixing springs - Eibach front and standard rear
Mi7rennie Nov 12, 2012
  1. Mi7rennie
    Mi7rennie Member
    82
    Hi Guys,
    I'm slowly working through the issues on my S3.
    I have found it has a broken rear spring and need to get it replaced ASAP before a road trip in a couple of weeks.
    I'm considering fitting the standard springs to the rear and leaving the Eibach lowering springs on the front.
    Has anyone ever run mixed springs on their S3, anything I could do to the standard spring to lower the ride height a little? maybe remove some of the rubber components that make up the spring seats?
  2. jojo
    28,835
    3,489
    I've ran Apex rear springs(eibach rears snapped aswell:() an Eibach fronts on mine to pass the MOT! lol There's nothing wrong with running different springs, the balance of the car will be effected I guess, as springs are usually matched front to rear for ride and firmness. Just buy a whole new set of lowering springs bud.
  3. aragorn
    17,956
    701
    Why not just buy new eibach rear spring? AFAIK the springs all have individual part numbers.
  4. Mi7rennie
    Mi7rennie Member
    82
    Well I was looking at that, the individual Eibach springs, but they aren't too cheap on their own.
    I have the standard springs here, so it wouldn't cost me anything.
    Was thinking of fitting the AP coilovers in the spring, so I just wanted something to keep me going until then....
    I just wonder what the ride height difference will be? The Eibachs seem quite low at the back.
  5. aragorn
    17,956
    701
    Ah well in that case get them nailed on and see how it is!
  6. Mi7rennie
    Mi7rennie Member
    82
    Fitted the standard rear springs today, looks good, maybe 10mm more arch gap on the rear, not taken it for a hard drive yet, but its got to be better than a broken spring!
  7. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    pics ! i'm thinking of jus lowering the rear due to a cracked spring
  8. Mi7rennie
    Mi7rennie Member
    82
    Picture of the S3 with Eibach front and standard rear springs, I think it looks pretty good!
  9. mattyboy199
    1,885
    cant really tell have you not got a better side shot ?
  10. Mi7rennie
    Mi7rennie Member
    82
    I'll get a better one this afternoon :)
  11. Mi7rennie
    Mi7rennie Member
    82
  12. Mi7rennie
    Mi7rennie Member
    82
    Another couple, I think the stance looks about right but the rear does feel a little soft when pushed on bumpy roads.
  13. jojo
    28,835
    3,489
    To be honest, I've always found the Eibach to sit too high up front when the back looks more squat. Looks more OEM now.
  14. mattyboy199
    1,885
    i'm thinking about just lowering the rear but wouldnt want to go anymore than 15mm however cant even find 15mm springs so 20mm may be the only option
  15. Tricki
    Tricki Getting into it
    114
    I ran H&R at the rear and OEM up front for a week or two - that was proper shait I can tell you. The car was close to unpredictable.
  16. jojo
    28,835
    3,489
    You need GmbH rear springs methinks.
  17. A19quattro
    A19quattro Active Member
    602
    91
    My care recently brok an Eibach spring, it was less than a year old and got replaced (in pairs) under warranty. Was a bit disappointed though, car had done about 3,000 miles in 10 months, to an from work, no uneven roads and well looked after, are Eibach as good as they should be?
  18. jojo
    28,835
    3,489
    Mine lasted 25k odd miles, but over 7 years or so before one of the rears snapped.
  19. mattyboy199
    1,885
    what are Gmbh rear springs ?
  20. jojo
    28,835
    3,489
    Factory lowering springs -10mm
  21. mattyboy199
    1,885
    is there a part number for these springs ?
  22. jojo
    28,835
    3,489
    I'm sure there is, but I don't know it. They are also marked with pink dots or something, so you can tell them apart from original factory springs. I do believe from past readings these were an optional extra on european(non uk) S3's, but on UK spec S3's these springs came standard for cars which had the 18" RSTT's rims ticked as an optional extra?
  23. Mi7rennie
    Mi7rennie Member
    82
    ah ha. The springs I just fitted on the back have the pink dot. Does that mean it's a sport spec spring? ?
  24. jojo
    28,835
    3,489
  25. richy1819
    richy1819 New Member
    15
    hi,ive just swapped my rear apex springs for the standard springs,and to be honest it looks miles better,mine had for pink dots on them and the rear only sits 10mm higher than the front,i know its not the best idea to have mixed springs but for the miles i do ( 30 miles per week) it does me,and in my opinion alot better looking ride height
