S3 8L Double DIN conversion
Routledge Dec 4, 2012
  1. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    I think your swap is a little different, as it appears you already had a double-DIN console in place, and have just bought a fascia adaptor to fit an aftermarket head unit.
    Does look nice though.
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    How you getting on?
  3. Routledge
    392
    10
    Little update, I finally have pretty much all the pieces now. The HU and blanking grommets for either side of the ESP arrived today.
    Have got the sat nav puck aerial too. I assembled it together loosely to make sure that I've not missed out any pieces.
    The only thing that's missing is the hazard light switch now. I thought I'd get away with using my existing pre-facelift one.. But I've just offered up the new fascia and it's actually bigger than the facelift so will be needing one of those too, d'oh!
    I've offered up the sat nav unit I bought, and can see that it's not an 8L one, and will either need some filing down the sides and a strip putting in above it (as informed, and expected to be the case), or will need to swap with an 8L unit.
    Couple pics:
  4. ScottD3
    15,166
    1,126
    Can you not swap the fronts of the hazard switch over like the B5s?
    Saves doing the wiring.
    Can you fit it but wait a month or so while you check eBay and spam forums looking for a swap or a proper 8L unit and then sell your B5 unit for a profit?
  5. Routledge
    392
    10
    Hopefully Scott. I'll have to see what the new switch looks like when I get it!
    Im tempted to wait till I can get an 8L unit before starting anything.
  6. lloydie1
    lloydie1 Member
    68
  7. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    183
    68
    Hi guys, im new to the forum, i am also planing to upgrade my prefacelift console to a double din style unit but i would like to keep my Climate control unit, I have a dvd headunit fitted st present but its not flush and it irritates me does any one know where i can source seat leon 1m double din as it has the same dash as the a3 and it fits with minimal modifications.
    my current centre console
    what im looking for (Seat leon 1m centre console)
    apologies for the thread hijack, i didnt want to create a duplicate thread on the same subject
  8. Routledge
    392
    10
    Thought I'd give a little update as have been fettling over the last week or two at slow pace.
    After scouting the 'bay for ages and not being able to find an RNS-D for 8L I decided to 'make' the one I already have fit.
    After some careful sanding with a more aggressive paper, and then fine grit to smooth it out, I got it to fit.
    It's not immaculate, but looks relatively good and I could always replace it with an 8L unit at a later date if one pops up.
    The only real issue is that (as I was warned) it left a gap at the top here:
    I was tempted to get a thin piece of aluminium and fit it at the top, but saved the hassle and instead opted to trim a piece of leather I had and fold a seam and fit it in place instead:
    Again we aren't talking perfection, but it looks presentable enough, and later on if I do get an 8L unit I'll just swap it over.
    Oh, and if anyone has a knack for getting radio codes without paying for the privilege I'd be grateful if they'd send me a PM with mine :)
    Here's the code:
    ~James
  9. ScottD3
    15,166
    1,126
    ooo and me. I got 2-3 units that needs codes.
    Routledge, I was thinking about you the other day.
    I should have given you my broken faceplate to cut apart, you would have removed the broken bits and i'd end up with a perfect faceplate. :(
    Looks like a tidy job though mate.
    How different are the B5 facelift top trim panel to your A3 unit?
    Cause ours is longer by about the amount you need.
  10. Routledge
    392
    10
    So I phoned up Audi today trying to get the radio code and apparently their process is to get the chassis number of the vehicle and submit the request alongside the serial number of the unit.
    I explained the situation and the guy was pretty cool, and basically said to give him the chassis number of my car and the serial of the unit and keep fingers crossed that its right. If it comes back with a result I can always just check the code against my existing unit's code and if it matches then I'll be 90% sure that I've been given the one for the single DIN already in the car.
    He didn't mention a cost either which is promising, just said when he gets 5 minutes he'll fire it over and see what comes back and took my mobile number.
  11. Routledge
    392
    10
    Winner! Got the code, and it was free!
  12. ScottD3
    15,166
    1,126
    Dude, amazing.
    ask him if he can get any more. lol
  13. Routledge
    392
    10
    I've just spent an hour pulling out the pre facelift single DIN unit, and then offered up the face lift double DIN.
    Everything is different. EVERYTHING.
    Only about 10% of the plugs are the same.. I'll take some pictures of how silly wrong it is and upload them when I'm done putting the single back in.
  14. Routledge
    392
    10
    I took a few pics as I was plodding along.
    The old console removed:
    The moment I realised things were probably not going to fit:
    Now for a list of plugs that wouldn't fit..
    The cigarette lighter power supply plug:
    The pre facelift plugs at the top (left to right: ESP, hazard light, rear demister)
    The facelift plugs (ESP, hazard light, rear demister part of climate control unit on facelift)
    Given the facelift slots at the top.. This is the ESP plug that would need to go in it:
    Pre facelift, and facelift in the background - Climate control. Please note the extra slot on the lift for the facelift.. This is where the de mister plug needs to go.
    This is the plug that's meant to fit in there!
    I was going to put the unit in and just wire up the things that don't work later.. Until I realised that the following wouldn't work:
    - Rear Demister
    - ESP button
    - Cigarette lighter
    The only thing that would work would be the hazard light switch, as the plug is the same.. and the head unit, once splicing in a safe feed.
    On this basis.. I put the single DIN back in:
    I then took the car out for a ragging to teach it a lesson for being a PITA.. and it retalliated by blowing a coil pack:
    I'm now firing on 3 cylinders till this afternoon when I replace it.
    FML.
  15. xapt3r5
    xapt3r5 New Member
    Hey guys, I'm trying hard to find a A3/S3 8L fascia adaptor for a 2 DIN aftermarket radio I have, but I just can't find one, anywhere. I know for sure that you can actually get one, cause I've seen a couple of pictures over the internet (like the ones above) where there are 8L A3's with aftermarket rádios installed. My car is a 8L S3 facelift from May/2003, I currently have a Symphony II unit in place. Can you people point me in the right direction, please? Sorry for the off topic. Good luck with your work...
  16. jack_davey
    jack_davey Member
    I also need above
  17. Platty
    Platty New Member
    I'm just going down the same road swapping a single DIN to a double DIN on a facelift A3.
    I've bought an A4 adaptor face plate which will require some fettling to shoehorn in. The AC controller I'll need to change, but I'll first see if the sides can be trimmed to match the curve where the cubby hole compartment sits, then work out if it can be fixed back in.
    I went for a Kenwood DNX520BT (with square edges) as it has the twat nav built in, can be colour coded (nothing worse than a multi coloured dashboard) and is touch screen. A fairly good package all in all. there's also a reverse camera to fit and then swap the speakers for a pair of Infinity Components up front and possibly a pair of speakers in the rear quarters in custom pods.
  18. Drewvic
    Drewvic Member
    204
    have one of these for sale if anyone wants one??
  19. Gops
    3,198
    666
    Facelift centre console? Or Leon 1m?
  20. Drewvic
    Drewvic Member
    204
  21. Cj_sat69
    Cj_sat69 Member
    77
    12
    Mate i spent about 3 hours today trying to find a way for making it all fit, im in exactly the same position as you. Its so fuc king annoying. The only way around it is to probably get the loom plugs of a facelift and to cut and solder every single 1. Im just going to have to try and sell my double din screen and goto a flip one instead unless someone can shed any light. Waste of time and money and now ive gotta try sell my double din screen and try look for a half decent flip 1. Not a happy bunny at all!
  22. Gops
    3,198
    666
    I think the only way is a Leon double din. I don't fancy cutting the wires, not worth it'
  23. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,131
    358
    Cj_sat69 and Gops like this.
  24. Gops
    3,198
    666
    Spot on jay! What a good find!
    Jay A3 likes this.
  25. Cj_sat69
    Cj_sat69 Member
    77
    12
    That is a wicked find, ill have to try out the climate control stuff hes shown there. Fingers crossed it will work.
  26. Munch
    Munch Member
    256
    23
    Got home early from work today so thought id give this a crack.
    im not doing the double din conversion, but just pre to facelift conversion.
    Problem I've found is in the a4 post, it shows the illumination pin missing from the 12 pin plug......mine is already there, but still won't illuminate.
    Ive got a mate with a facelift s3 who has kindly said i can borrow it for the day and to check and log what each wire does.
    As soon as i have an answer, ill let you all know.
    Its purely the ac panel thats causing me headache. Hazzard is like for like swap, demister switch just needs 2 wires extended, and ash tray light will be easy too.
  27. Gops
    3,198
    666
    Did you switch your lights on to illuminate it?
  28. Munch
    Munch Member
    256
    23
    Yes fella
    I've got a horrible feeling the ac panel I've bought is faulty, so will plug it into my mates s3 when i get hold of it
  29. Jay A3
    2,131
    358
    Bump
    Anyone got any further on the AC unit issue? My pre facelift AC unit works. Swapped the facelift one over and nothing... No power no illumination. I also thought it could be the unit may be faulty so I borrowed another one that I know works. Still no joy...
  30. Gops
    3,198
    666
    Did you pick out pin 6 on connector A for illumination?
  31. Jay A3
    2,131
    358
    Pin 6 is already populated with a wire. There's no power at all to it.
  32. Jay A3
    2,131
    358
    Both Hvac units. Looks exactly the same apart from the rear demister plug on the face lift unit.
    Facelift on the bottom
    Preface lift on top
    From left to right
    Plug D = 16 pin
    Plug A = 12 pin
    Plug B = 20 pin
    Plug C = 16 pin
    Scottb5 has had a look for the wiring diagrams on Elsa win for me but we are struggling. Plugs may be the same but pins look like they may be routed differently which is strange as the b5s are a similar setup and they were plug and play... Can anyone shed some light on what pin is what for both units?
  33. AudiA3V5
    AudiA3V5 Member
    35
    Is the process/setup the same in the S3 and A3?
    I have just bought an A3 and need to clean up and refresh the interior a bit and would like to Double Din it as well, so this is all quite interesting.
    When was the S3/A3 facelifted? Or was it just the S3 facelifted?
    Mine is on an '02 plate, which is quite late I believe for the 8l chassis so I am assuming would be facelift?
  34. Jay A3
    2,131
    358
    Yours would be a facelift. I think they were from 2001 to 2003...
    I think yours would be much simpler to go from single din to double din. New double din cage and new lower hvac unit - plug and play as your wiring is the same
  35. ScottD3
    15,166
    1,126
    I got no idea why yours is so hard mate.
    Its stupid.
    B5, which looks like it uses the same units with different faces, same plugs is just a simple plug and play.
    I can't see why they would completely change the wiring on a A3.
  36. Jay A3
    2,131
    358
    Me either. Thanks again for your help yesterday. I think I will need to identify each pin starting with the power and seeing if both are located in the same place....
  37. ScottD3
    15,166
    1,126
    You got the diagrams but I don't understand where the other plugs are.
    It only lists some and no idea what the 10 or 17 pin plugs are.
  38. Jay A3
    2,131
    358
    Yeh I'm going to get someone who knows electrics better than me to see if he can make sense of the diagrams
  39. AudiA3V5
    AudiA3V5 Member
    35
    Cool, cheers mate. Let's hope so. Anyone know part or model numbers on the lower HVAC units? Just to make it easier to find on eBay. Lol
  40. Mr Footlong
    Mr Footlong Stalking Kate Beckinsale
    52
    Guys, I have a brand new double DIN cage assembly available and the correct HVAC unit for it (albeit with beat to hell buttons sadly, took me 9 months just to get this) that I don't need as I never got around to doing the conversion and am selling the car.
    8L0 858 005 A - Cage
    8L0 820 043L - HVAC
