S3 57 plate Revs bouncing up and down between 1000rpm and 2000rpm HELP
NIC1985 Jan 14, 2013
  1. NIC1985
    NIC1985 New Member
    25
    MY S3's REVS ARE BOUNCING UP AND DOWN only when sat stationary at the lights etc it seems to pull ok although it gives the odd judder whilst accelerating hard
    i recently had the timing belt changed but it was fine till about a week later when i dropped oil and changed it for a 5 x 30W
    IVE CHANGED THE PLUGS SINCE IT STARTED DOING THIS, ALSO CHECKED THE COIL PACK AND IT DOESN'T SEEM TO BE THAT EITHER, I DISCONNECTED EACH COIL ONE AT A TIME TO CHECK THOSE AND IT ONLY MADE IT WORSE,
    FAULT CODE IS COMING UP AS > HEAT TEMP SENSOR AND > IDLE FAULT
    HAS ANY1 ANY IDEAS AS TO WHAT THIS MIGHT BE OR WHERE I SHOULD START TO TRY FIND THE CAUSE IM BAFFLED AND DONT WANT TO START THROWING MONEY AT IT?????? [​IMG]
  2. BENJAMIN
    BENJAMIN Active Member
    503
    93
    You need to post in the 8p section as you're in the older 8L model forum.
    But........ Your problem sounds like a split pcv on the rocker cover. Very common on the tfsi. Do a little google search about it, very easy to fix. :)
