S3 09 Faceift with LED DRL's switched on in the off position via VCDS?
ApolloS3 Apr 19, 2013
  1. ApolloS3
    ApolloS3 Member
    73
    10
    Hi guys,
    I have auto lights on my S3, im just wondering as a few people on here have mentioned it can be done, does anyone know where in VCDS you can enable DRL's to be on in the off position?
    My mother has an A1, her drl's are on constant at full brightness when the lights are at the off position. I want this on my S3 :)
  2. monopole
    monopole Well-Known Member
    1,154
    471
    yes it can be done via VCDS, but right now I cant remeber the code.
    I did it a while back but didnt like the idea of it, so set it back to default
  3. monopole
    1,154
    471
    [h=3][09] - Central Electronics / Body Control Module (BCM)[/h] Note: Make sure to have all Doors unlocked, otherwise this Control Module may not communicate with the Scan Tool / VCDS.
    [h=3]Lighting[/h] All modifications are found in Found in [Coding - 07] > Long Coding Helper unless otherwise noted. Click on each of the Bytes and Bits for the documented options and check or un-check the appropriate boxes as shown in the example below:
    [Select]
    [09 - Cent. Elect.] Or the module you intend on tweaking as per the list below
    [Coding - 07]
    [Long Coding Helper]
    Daytime Running Lights enabled with OFF and Auto switch positions - common when importing vehicles from the US -to- Canada
    Disable "Daytime Running Light (DRL) only active with Assistance Driving Light (ADL) active"
    Audi A3/S3 & A3 Cabriolet (8P/FM) Tweaks - Ross-Tech Wiki
    ApolloS3 likes this.
  4. ApolloS3
    ApolloS3 Member
    73
    10
    Exactly what i was after, thanks, will let you know how i get on.
  5. ApolloS3
    ApolloS3 Member
    73
    10
    Just had a look through VCDS with a friend, couldnt see that option anywhere. The only thing we could do was change it from US to Scandinavia, which also has done nothing to the sidelights. Maybe it just cannot be done on mine (58 plate facelift model).
  6. monopole
    1,154
    471
    you don't have this: bit3
    try this: bit6
    (extracted from the interwebz, the controllers are different)
