S2000 air filter
willh92 Feb 5, 2014
  1. willh92
    willh92 Active Member TFSI Owners Group Silver Supporter Team Brilliant Black Audi S1
    408
    I've seen many people have them fitted on here from reading signatures and stuff. Anyone got a pic of theirs fitted?
    Also, is it a simple remove our air box and fit the s2000 cone on the end of the MAF? and job done? Or is there more to it ...
  2. Spatula
    Spatula A4 B6
    272
    26
  3. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,927
    760
    on a S3 it's a straight fit onto the end of the MAF
  4. Spatula
    Spatula A4 B6
    272
    26
    I'm currently trying to find one. My local Auto factors has one but they want £32.00 for it... where's everyone getting them frommmmmmmm :(
  5. Freeman_1986
    Freeman_1986 Member
    169
    21
    Ebay
  6. Adam P
    Adam P Active Member
    539
    178
    43
  7. Spatula
    Spatula A4 B6
    272
    26
  8. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Have a read of this, Adam;
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/118673-benjamins-s2000-air-filter-mod.html
    Or this;
    Honda S2000 AP11 2.0 Vtec OE Quality Standard Replacement Air Filter | eBay
    And yes to the reducer, from reading the thread above...
  9. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    I think Euro Car Parts do them as well for a decent price.
    Just checked they do have it for £18.60
  10. JD09
    3,096
    46
    All out of stock, Nilz buddy. ECP, GSF, CP4L :(
  11. Nilz
    11,367
    908
    Aah ******!!!
    Ebay it is then.
  12. Spatula
    Spatula A4 B6
    272
    26
    I just called Honda on a whim as theyre only around the corner from my work, and open til 5:30pm. Picked one up for £22.50..
    Just need the reducer now :)
  13. Bennys3
    Bennys3 Member
    110
    17
    I just went direct too Honda for mine £20 all in! I do have a question tho what material are your s2000 filters made of? Not the actual filter but the body of the filter is it hard plastic? If so how do you make it fit an s3 is mine doesn't fit all that well?
  14. Spatula
    Spatula A4 B6
    272
    26
    Yup, mine is made out of horrible lime green plastic.. Not sure about S3 fittings, though.
  15. Freeman_1986
    Freeman_1986 Member
    169
    21
    Yeah still slips over the maf. I put a small brad of silicone around it to make sure it was sealed properly and cable tied the end to make sure it wouldn't slip off.
  16. Bennys3
    Bennys3 Member
    110
    17
    See I tried just slipping it over the maf but it doesn't really fit all that well? It's really right and doesn't stay on all that well tbh it falls off! So I have ordered a straight bit of 80mm silicone hose so should be fine soon
  17. willh92
    408
    For the SAI pipe that is left on show when the airbox is removed, I don't plan on deleting the SAI system, instead I'm going to cable tie to under the come filter and put a smaller filter on the end of it, as provided with Neuspeed induction kit. Does anybody know the diameter of the SAI pipe so I can also buy a small filter for it?
  18. willh92
    408
    bump, anyone?
  19. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    25 mm should be good
  20. Spatula
    Spatula A4 B6
    272
    26
    Ok so I did it and now my dump valve is making a stupid noise. Also feels like it's sloppy at spooling up?
  21. MyCarling
    MyCarling New Member
    17
    I have fitted my s2000 filter to my AGU into an aluminium heat shield off ebay and its sounds ridiculous when the dv dumps the air. It sounds a bit like a Dyson echoing lol. Also what am I supposed to do with the sensor that was attached to the top of the air box? Not sure what it does lol
  22. Spatula
    Spatula A4 B6
    272
    26
    Yeah it's just like a fluttering sound.. I think it's torn the diaphragm or something?..
  23. MyCarling
    17
    I haven't got a diaphragm tho lol its a forge style dv
  24. s3dave
    10,110
    736
    That will be your ignition amplifier so needs to be carefully tied up somewhere..or fasten it to the heat shield you got of ebay,,,,,;)
  25. MyCarling
    17
    I may sound thick but what does it do exactly lol. When I unscrewed it from the airbox only half of it came away from the box. Do I need to get the other half out of the airbox. That part looks like a heat sink of some sort. Does it need to be fixed inside the heat shield?
