S2000 Air Filter
Pubemammal May 19, 2013
  1. Pubemammal
    Pubemammal Active Member
    525
    117
    43
    Hi guys I have decided on fitting an OEM Honda s2000 cone filter to my AGU engine.
    Does this filter require a reducer or will it jubilee clip straight onto the MAF? Standads air box is easy to remove I assume?
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,149
    1,986
  3. Sam_
    Sam_ Down under
    3,038
    480
    This is covered approximately every 20 minutes. At which point, Jardo piles in claiming it's the best thing since sliced bread. There's no real evidence apart from logs which vary at the best of times and the old "it feels good" placebo. It is cheap though, and paper is meant to give better filtration.
    kwistof, [Dave B] and voorhees like this.
  4. Tim_Attard
    Tim_Attard Active Member
    473
    44
    really its jetex or the s2000 or put it another way £50 or £15 (not sure actual price) but have a look in that thread, i had to buy a reducer for mine i have an aum
  5. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    LOL Sam. You make me piss.
    Do you know who put me onto the S2000 air filter originally? Bill. If it is good enough for Bill it is good enough for me. Even if it doesn't add any performance over a Jetex it does the same job potentially better for less than a third of the cost, so of cause it is the best thing since sliced bread.
    And as I say all the time, if my S2000 air filter wasn't up to the job I wouldn't have the most powerful K03s on the forum. As you know with a K03 it is ALL about flow.
    I have seen a couple of S2000 turbo setups, ranging from 300 to 500bhp all using this standard filter and airbox.
    You just don't like it because it isn't a brand name to out on your list of perfect mods :p
    Tim_Attard likes this.
  6. Pubemammal
    525
    117
    43
    Can you point me in the right direction on where to purchase a reducer please buddy? Is it just a standard 70-80mm silicone reducer I need? Sam
  7. Tim_Attard
    473
    44
  8. Pubemammal
    525
    117
    43
    That's great thanks buddy :) Is airbox simple to remove? Is it the AGU or AUM that has the little sensor on the air box that you have to fix somewhere else?
  9. 16Klappe
    5,795
    1,184
    Agu has an ignition amplifier in the airbox, just zip tie it somewhere out the way but as far away from the engine/turbo as you can.
  10. Tim_Attard
    473
    44
    i have an aum and didnt see a sensor, its so easy to remove just 4 bolts/screws 2 either side
  11. 16Klappe
    5,795
    1,184
    That's because AUM's don't have the ignition amplifier in the airbox, it is built into the coil packs. Four wires for the coil packs, not three like an AGU.
  12. Pubemammal
    525
    117
    43
    I'm guessing all you guys with a3's and s2k filters had to use the 80-70mm reducers?
  13. 16Klappe
    5,795
    1,184
    Yup, in one way or another. But the entrance to the filter is actually bigger than 80mm, more like 82/84mm. An 80mm will stretch, but it's a push.
  14. Gops
    3,198
    666
    Was your filter oiled jardo? Mine was caked in oil!
  15. 16Klappe
    5,795
    1,184
    No oil in mine; I got my filter from GSF.
    You shouldn't need to oil a paper filter? Hmmm.
  16. Gops
    3,198
    666
    I got mine from eurocarparts, was caked in oil when I took it out the box?
  17. Tim_Attard
    473
    44
    if you get the reducer i linked you too it fits so snug does take a bit of pushing tho
  18. Pubemammal
    525
    117
    43
  19. Neil-M
    Neil-M remedy
    33
    1. [​IMG]
      Offline
      16KlappeRacecaR forward is RacecaR backwards.Supporter
      [May 19, 2013]
      May 19, 2013
    2. Just a quick one on this mate, the amplifier on the top half of the air box is held on with 2x cross heads. I removed these and then proceeded with removing the amplifier, only to find a white paste (heat paste?) That was on the face of the amplifier removed and then on what looks like cooling fins which remain in the top half of the filter box!, what needs to be done here? As without the two connected it cause the car tho cut out. Cheers buddy and great build.
  20. RobinJI
    RobinJI Active Member
    177
    27
    The heat-sink like bit should have come away from the airbox and remained attached to the amplifier. I can't remember exactly how the heat sink's held to the air-box as mine never came with an air-box attached, but they should be connected together as the heat-sink will be needed. It's a good idea to have it somewhere with a bit of air-flow to it if you can.
  21. Neil-M
    Neil-M remedy
    33
    Cheers mate. I will have a look and see what's what.
  22. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    The S2K filter doesnt hold back anything, when on the dyno if you run with and then without it makes no difference to air flow, they are that good
